Sorry if this has been mentioned before, but it appears as though the vrayHDRI map ‘tile’ checkbox isn’t respected in the viewport. The standard bitmap loader doesn’t have this issue.
Patrick.
I would also add that the real world mapping doesn’t work either.
It’s not possible to apply a maps that goes outside the bounding box of the real world uvw.
Stan
Thanks for the feedback - I’ll make a note about it into our system.
Is this report for the Viewport Background too or do you mean something else?
Hey
Here is a example of where the VrayHDRI viewport maps is falling down. It’s not related to viewport background but to standard maps in the viewport.
Both planes are 5000mm and the uvm map to real world map size (1000mm)
Here is the link to the file if needed :
https://dl.dropboxusercontent.com/u/368267/map.zip
Cheers
Stan
Thank you very much for the screen-shots and the scene.
I’ll make sure that this issue is also added into our system.
Having no visual feedback on real-world map size in viewport is really slowing things down. Especially if you’ve converted all your bitmaps to vrayhdri with the script and need to adjust some minor texture placement issues.
Really looking forward to the fix!
Ditto! Makes me still work with regular bitmaps actually. Question is apart from maybe missing a few features does it have an influence on rendering speed?
Usually changing from regular bitmaps to vrayhdri also knocks down the rendertime, sometimes quite a bit.
This issue should be fixed in the latest 3.30.03 version.
Awesome, looking forward!
