Is it possible that VrayObjectProperties do not work on objects with selection in GPU rendering?
Hallo,
Kann es sein, dass VrayObjectProperties auf Objekten mit Selektion im GPU-Rendering nicht funktionieren?
macOS Catalina, Cinema 4D R21, Vray 5.20.00 from Dec. 8 2021
Best regards
uwe
Dear @pardalis ,
Upon testing this on my end I couldn’t reproduce the issue. Have you simply added a VRayObjectProperties tag? Have you by any chance enabled the Matte Surface option in the Matte Properties tab? Would you mind sharing a test scene where the issue is reproducible so I can have a look? Also, you mentioned that this issue happens when rendering with V-Ray GPU but you also mentioned that you are using macOS. As GPU rendering is not supported on macOS, could you please elaborate more on that part? Thank you.
Hello @pardalis ,
Apologies for my previous post. Upon testing this again I managed to reproduce this issue. It seems like a bug on our end and I have reported it to our devs for fixing (bug ID: VC4D-1203). I will keep you updated on its progress. Thank you.
