The current VRaySky allows to render clouds only when camera is located below clouds. Can we get clouds which will work correctly when camera is above clouds?
Similar discussion here. In short, it’s a limitation.
Using VDB clouds are a viable, but more costly solution.
Since this is not the first such a request, we will consider it more thoroughly.
Do you still need to go through the clouds, or just to have a view above them?
Let us know about the exact use case.
Camera going through the clouds would be great. But in most cases even ability to have camera above the clouds would help much. Thank you for looking at this.
Please fix broken link for VDB Clouds Cumulus_A hi_rez download you provided. The link directs to the wrong file.
Thanks for the report. I notified the Docs team about it - it will be fixed asap.
EDIT: The link is fixed now.
