It works as intended, yes. It would work best with a V-Ray camera, but if you want to use a standard one, there are several things to do. You can adjust the horizontal illuminance of the sky; you can also adjust the color mapping bright and dark multipliers, or you can pipe the VRaySky texture through an Output map and adjust its intensity there.
