VraySun strength independent from VraySkyStrength
Don’t know, if it is in the latest build already, but it would be nice to have independent control of both. Might not be physically correct then, but still …
In our case a client would like to have the sunlight dimmed, but the sky should remain the same …
Possible?
Best regards, Peter
You can do that if you use one of the CIE sky models; you can also do it if you turn on the “manual sun node” option in VRaySky - even if you pick a VRaySun light there, you will still be able to adjust the sky intensity separately. And finally, you can put the VRaySky inside an Output texture and change its output amount.
True. Probably better not to cloak the interface with additional controls.
Best regards, Peter
