I need to render a high res image that is crashing my computer--I am trying to use the vrimg file format--are the render elements such as zdepth stored in this file? cant seem to find them!
When you open the vrimg file do you just use the normal image viewer in max or is there a vray image viewer?
thanks tricky for the quick post--I am using vrimg2exr now but am still having trouble getting my zdepth file--I am posting some images of my command lines--thanks again for your help
definitely get the latest version from the downloads section. Also, you can render to exr using the VRFB. Just change the extension. Check out the help documents for more details.
