Hy,
were can I download the following file: vrim2exr-plugin for Rhino?
Thanks for a reply
rendy
Hy,
Thanks for a reply
rendy
Re: vrimg2exr plugin
I’m not sure how much longer this link will be valid, but here’s the link directly to the converter
hy dalomar,
thanks for your reply, the link is still available!
Man, where can I get this converter? I have some vrimag files sat here on my drive that I now need converting. Searching the forums has proved fruitless.
*edit* I need the sketchup version…
Asgvis.com → Downloads → ASGVis Tools → Page 2: http://software.asgvis.com/index.php?option=com\_content&view=article&id=57&Itemid=439&Ctitle=Asgvis+Tools&limitstart=6
thanks ThomThom..no offence but that dowload area is a nightmare to navigate. Anyway, back to work!
Well, I find it confusing that the download for VfSU and VfR is located in the Support section - instead of Download. Then there’s this new Downloads link in the forum on the left hand side which does … nothing?
Then if you go to the main asgvis site and login there you get a link that says “Download Area” - which prompts you for a “Download-ID”.
So yes, I fully agree - the download section(s) at asgvis.com are confusing.
The Download section on the left hand side should be gone now.
