.vrmat exporter issues.
Texture connected materials are not exported correctly to .vrmat files in V-Ray 6, Update 2.1.
(.vrmat files are saved, but cannot be read by VRayVRmatMtl).
Well, exporting the .vrscene is an alternative, but this is a bug report just in case.​
Works fine with a simple material. Maybe it’s something specific. Mind if you send a sample scene?
Thank you for trying. From this, there is a possibility that this is a problem specific to the 3dsMax Japanese mode.
This is a capture tested in 3dsMax 2025 JP mode.​
https://drive.google.com/file/d/1MWG…ew?usp=sharing
Attach the output .vrmat file.
test007.zip (2.16 KB)
Thanks for the report. It’s reproducible in the Japanese version. Logged (internal bug-tracker id: VMAX-14106).
