I need to convert vrmesh back to max editable mesh.
Is there any updated script (MAX 9) to do it?
I’d be more than happy to oblige, if the VRmesh format is described anywhere, or can be recovered.
Well, the file format itself is not described, but the V-Ray SDK that comes with V-Ray for 3ds Max contains a set of C++ functions for reading/writing .vrmesh files.
I’ll dig and check what format it’s into.
And of course bug you in case (likely) i’ll find troubles ![]()
If the proxy was created in Max 9 it can be directly converted although you lose all multi-subobject material assignments.
Cheers
Mike K
HOW???! ![]()
Right click on the proxy and select convert to editable mesh and boom you have a mesh. This HAS to be a proxy created in Max 9 and VRAY 1.5 final, Max 7 Vray 1.47 proxies come in messed up still…
What you will get in this way is the mesh of the proxy viewport preview, not the actual underlying mesh that gets rendered.
There is a script posted already by corey I believe, ages ago.. its hard to find in a search but its there.
I will look for it a little later.
indeed DaForce, seems Corey has made a script/plugin for this,
http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=31126
dunno if it still works tho.
I had used this plugin in the past, but it had some overhead and scenes with lots of objects became extremely slow, and it took a while until we figured it was due to the plugin.
It doesnt work with max 9.
I think hat’s been kept updated, and it should now work under x64.
What i didn’t particularly like (especially under 32 bits) was that it didn’t stream the conversion, it loaded in ram the whole proxy, and that caused some major issue back then.
It remains to be seen if i can handle the proxy file format, but i’ll try and get something out of it, at least as a scripted (rather than compiled) alternative.
ok but where is the updated script for max 9?
I have spent 2 hours looking for it and only find the old version.
You should ask Corey of ASGVis for it.
I think they kept it somewhat “internal” of late.
