VRScene images path
Hi, i have problems with writing out vrscene files with correct “img_file” paths.
Right now i am using this command:
mel.eval("vrend -layer " + layer + " -camera " + camera)
My file prefix in the render settings is set to:
%s/%s
Vray always adds “tmp” at the beginning of the path, you can see an excerpt from the written vrscene file. This also happens when i do a render directly within maya, not from my script.
SettingsOutput vraySettingsOutput {
img_file=“tmp/layer1/vrsceneTest/vrsceneTest.png”;
img_dir=“Y:/1364_xxxxx/02_WORK/03_3D/05_Maya//./../01_renders/”;
Is there an argument i can use in conjunction with vrend to set the img_path?
Btw, i had a hard time finding all arguments for vrend, could not find any description in the manual. It still behaves weird, since i have to switch to the renderlayer i want to export before executing the actual vrend -layer command. Otherwise just the actual renderlayer gets rendered.
Vray Version is:
VRay nightly 2.45.01
Windows 7
Maya 2015
Thanks in advance
This is how VRay behaves in Maya, as do all other renderers. Here’s an excerpt from our help files:
Keep in mind that when rendering a single frame, V-Ray saves out the image file to the project_root/images/tmp/filename.ext or to any subfolder of the images directory if specified (project_root/imates/tmp/scene_name/filename.ext). When rendering animation, V-Ray saves out the image file without pre-pending the “tmp” directory: project_name/images/filename.#.ext.
I hope that this is helpful.
I see, this makes sense now, still i need to get around this somehow.
Is there any chance of using an attribute with vrend to set the file path myself?
My problem is, that i need to have a post translate expression in my file that does not evaluate properly when i use batch render, because i need to query the actual frame and on batch rendering this always leads to the frame being evaluated to 1. Workaround is exporting vrscenes one by one, that works, but i end up with the wrong paths.
A stupid way of fixing this would be to parse the vrscene file and exchange the path after the file was written, but i would like to avoid that.
The batch render will not pre-pend the “tmp” to the path, but yes, now there will be the problem with the post-translate script.
Rendering 1 frame in animation will give you the paths you want, but will add the frame number to the file name.
Is what you’re describing related to rendering/exporting animation ?
I’m still discussing with some of our developers to come up with something that will be helpful to your case.
If you are already using post translate script, you can use this to change the path:
from vray.utils import *
so=findByType(“SettingsOutput”)
so[0].set(“img_file”, “test.png”)
and it will write the image where you like it with whatever name you like.
Thanks for the tip ivaylo.
I will try this out, just have to make sure i find a good way to deal with all the different renderlayer/camera naming possibilities. But a script is taking care of the export already, so i can adjust the post translate script also for each pass if i would like. Maybe only if it is actually being written to vrscenes and not when rendering locally. Then tmp is basically fine.
@ yolov
Yes, this has to do with exporting animation, it is actually a massive integration script that i am working on, everything works smoothly with the exception of this tmp path issue.
OK, then. I hope that what Ivo suggested will work for you.
