Please feel free to give me your comment. ![]()
there are some shadow problems at that cabinet and those ceiling lights are too much of an eyesore
the rest is fine
really nice ! ![]()
I like it ..
I think the chair need some shadows cos it looks like it’s floating a little,
I like the cover material..
can you share your “cover” material settings please, ?
well,keep 'em coming ![]()
Hussam
but i’d been trying to make bookcase strick to the wall, but when render it which make me feel the bookcase isn’t strick on the wall as i think. you can see it has a gap between the wall and bookcase.
i reckon the reason is the render setting or the lighting, maybe ? although, i have tried many times but can’t get better result.
Can someone help me that ?
Here is cover mat, Hussam_CG:
it’s very simple to create:
i think i know why your bookcase and chair look like they are floating - is your scene in scale? i mean do you work in cm ? if not..try to re-scale your scence working with cm then render (i think you’ll may need to delete the lights and then creat them again) let me know if that helps
Either blow out the lights coming in from the outside and put a completly white background making it a more dramatic image, or put some sky and image to the outside. This way its something in between and really nihilistic and its practicly sreaming “there is nothing outside”.
ok, i’ll test and post the result soon !
thanx !
