This is going to sound pretty dumb, but the main thing that seems to give my interior renders that “CG” look is the walls. Ive been messing around with this problem for a while now, and just cant put my finger on it. I know this is a pretty broad question, but any tips would be helpfull. Ive scoured this forum and havent been able to find anything specific.
Any advice would be great. I can post some examples and settings if needed.
I am assuming you refer to the realism of the lighting on the walls. In my experience, to achieve realistic results in the lighting for an interior you have to be willing to wait for VRay to do it’s magic, or be extremely proficient with fill-lighting.
Bumps! It’s all in the bump map. No wall is perfectly flat. Most surfaces have scratches and dents etc. Also, no surface is perfectly diffuse. It usually helps to add a small amount of wide hilight. You can turn off the actual reflections for speed and keep just the hilights.
Thanks for the input everyone. I do always use some kind of bump, and a slight reflection. I am thinking that I should paint the wall bump maps in PS. Mabey the uniformity of the bump is to noticable. I have an example here…
I know that I need to lower the GI on the sills, but something about the walls is just not right. I used pretty high settings on the lighting. Any way, thanks for the responce.
BTW, still find it amazing that the developers actually read and post on this forum (or any forum for that matter)
