Weird messages when rendering
When i hit render i can see these messages and are really new to me, had never seen before, is there any problem with my scene?
Apart from this the render goes fine :slight_smile:
Probably you use “Raytrace” map for your material/s.
You can try to find them in the Material Editor and turn them off.
Or if you want just to hide this window, you can set Render Setup/Raytracer/Show Progress Dialog to Off
Yeeep, an “Architectural” material was there around, solved, thank you!!
