Weird Velocities
Hey Guys,
I have this really weird problem with alembic caches from maya giving me crazy velocities in Pheonix for 3ds max. For Alembic Exporters I used Crate and Std Maya - both give me the same weird results. Any Ideas what’s causing it or how to fix it? (btw it goes away when I disable “animated verts” in the phoenix options - but then I also dont get correct velocities fro the emitting obects)
pw: stung
Another thing that I noticed while troubleshooting was that I can’t edit phoenixfd properties for multiple objects (the window just doesn’t open) - is that intentional?
It also seems FumeFX doesn’t have this problem. No Fire Shootouts there.
pw: stung
Please don’t make me use FumeFX!!!
can you send one cache to test it?
I can’t pm you. Which mail?
phoenix@chaosgroup.com
The issue is fixed, you can check out tomorrow’s nightly build. Thanks for the report!
Hey,
Is this issue also fixed for the 3ds max version? I had similar issues with alembic files and super accelerated velocities but for liquids.
Yyyyup, both max and maya should benefit from the fix :slight_smile:
Awesome! Where can I find the nightlies? My Account is Geddart.
aks the support for nightly access, they will explain you how to use them
Awesome thanks :slight_smile:
