What are your specs and settings for VR?
First of all I would have posted this in a general discussion group, if that existed. So I suppose it fits best here?
I decided to ask the community what specs and hardware you use on what settings for VR using Enscape. This has less to do with Esncape itself, and more to do with how things run with what hardware and settings. As I am looking at upgrading this or that, and looking at better resolution HMD’s, something like this would help understand better on where to spend money on. This includes anything from system specs to monitor resolutions to HMD, and only what is in use (that might matter) while using VR. So I will start:
My specs:
OS: Win 10
CPU: i7 7800X 3.50GHz
RAM: 64GB DDR4
GPU: GTX 1080 Ti
Monitors: 4K monitor running at 3840x2160 resolution for operating.
Monitors: HD TV running at 1920x1080 resolution for display/ presentation purposes.
HMD: Samsung Odyssey Mixed Reality running at 1440x1600 (per lens), for a total of 2880x1600.
Enscape: Medium Settings. All other settings pretty much on default. (High and Ultra only works perfect outside VR, in VR it starts getting choppy, and sometimes just completely uncomfortable)
This is solely to compare specs with each other, as I would like to spend wisely, and maybe/ hopefully get some hints from others. As I am always looking at better HMD’s, but am realizing my GPU would/ might not be up to it. If this post does not fit here, or anywhere on this forum, admins may delete this, as I am not even sure where to post this or if it fits anywhere.
Thank you
