what's up with exr, color adaptation etc = burnouts
How on earth Bertrand and others who are using “don’t affect colors adaptation only” on, are able to avoid burnouts.
Here’s some rough render with Reinhard color mapping :
and “don’t affect colors adaptation only” exr output opened in photoshop :
also notice with exr and color adaptation only , lack of shadows (behind tv)
is it not possible to fix this by using a lower external light intensity, and/ or reducing the reflectivity of those surfaces? im not sure if there is something simple like a button youre missing. if you start building the scene with “dont affect colour, adaptation only” turned on (as i usually have) then you just light and texture the scene to avoid burnouts. i dont know if you have other lights in the scene, but it looks to me like youre asking the external light to do too much. in a real scene it might well be darker in the foreground (the result youd obviously get if you reduce the light intensity) then you can just use levels in ps to bring up the darker areas? saving as exr you have all that nice colour range to play with after all.
no idea regarding the missing shadows though ..
hmmm I guess I will have to try this. So far I tried playing with hdr toning in PS but it’s horrible.
Lukx, interesting point. I used to always tick ‘dont affect colors’, but of recent I have been leaving off and using reinhard to reduce burn, I find it really lets you get more natural light in without burnouts albeit at the expense of sampling/noise issues. Interestingly, whilst Bertrand seems to get such great results with it on, P.Guthrie gets equally as excellent results with it off using Reinhard (pretty sure he menioned this on his blog).
yeah, regarding the noise I also noticed more problem with it when “dont affect col” on. But this missing shadows is boggling my mind now. Hope Bertrand will show up can shed some light on this topic.
I guess don’t affect colours it’s really meant to be used with a proper linear workflof, where you output to exr and the only colour correction you do is gamma 2,2 in linear mapping. this way the render will look exactly as you see it in the vray fb with “display colours in srgb space” checked (well, almost exactly that is..). with any other colour mapping and/or correction you won’t get consistent results, as the reinhard colour mapping won’t be stored into the saved exr.
anyway, I usually don’t use reinhard myself. what I started doing to avoid burnouts and retain decent contrast in lfw renderings, is darkening materials. it goes for reflection colours/values as well.. but I guess whatever does the job is as good, and sure reinhard colour correction is a good method to achieve pleasant and realistic light distribution.
I wish I could help but I’m not quite sure why I’m not getting these burnouts. But I think Super Gnu hits the nail on the head. If you do everything (modelling, shading, test renders) using the same setup, i.e. with “don’t affect colors adaptation only” and sRGB on, as I do, you will naturally light your scene and adjust your materials so that they don’t produce burnouts. Then again, there are situations where burnouts are unavoidable and indeed correct, photographically speaking, especially if you rely on external sources alone to light a rather dark interior and you have pretty bright materials close to the light source. For instance, as I believe I wrote somewhere else earlier, my whites are actually closer to grey and the RGB values for other solid colours are pretty dark too, which may explain the lack of burnouts.
As for the absent shadows, I’m pretty sure they are there, but the second image is a lot brighter overall (look at the bottom of the bookshelves), wich may make your shadows look fainter. If you output to 32 bits and lower the exposure in PS, I’m pretty sure they would show up again.
I think, changing to “don’t affect colors adaptation only” is changing the intensity of the color that you have on the reflection parameters so what you see there is the white background.
What kind of tone/curve mapping are you doing in photoshop? What’s your Reinhard burn value? I never understood how well photoshop handles >1 values though for 32bit files since the curve editor, etc max out at a value of 1.
reinhard was at 0.4 for bright. the exr version I posted didn’t have any tone/curve applied. Basically with EXR there’a only HDR Toning available , Exposure and levels. No way to apply curves.
Totally forgot PS can’t do curves in 32bit! Other than exposure do any of the other tools push the +1 values back into the <1 range. Without that I don’t think there’s any way to match the reinhard output since it’s affecting all of the values, trying to keep the +1 values back in normal range. I think your only option is to lower the camera exposure and then push the image levels in photoshop (perhaps using levels?.) just a guess though.
Magic Bullet Photolooks allows lots of tweaking, including curves, in 32bits straight in PS (or as standalone).
but bullet can’t open exr and when saving 32 tiff , standalone still won’t open it. I can’t use photolooks filter (this works) because it’s not working properly with wacom tablet (I’m not using mouse anymore).
So maybe I’m just missing something how to open exr in MB
Well if you want the same result you have to apply the same color mapping in post. If this is what you want and you do not need to be linear then i wonder why bother tho. We have to for various reasons and it works perfectly fine when done right. It will NOT give the same results as with burning in ever. Not even with all settings adapted (don’t know if you did. But it seems to me you only turned on “Don’t affect colors” which essentially simply turns off any color mapping besides for sampling, and this will result in different results alltogether)
Regards,
Thorsten
this ma be quite stupid question but
what do you mean by working completely linear?
using linear colormapping at 1 and burn value at 1 and not clamping anything (plus the typical max gamma setup in preferences) and then saving to 32bit depth???
In short as in:
-Setting your Max Gamma/LUT settings to 2.2
-Setting your color mapping to linear multiply with dark 1.0 ,bright 1.0 and gamma 2.2
-Turn on “Don’t affect colors” and save via the VRay VFB
(- Naturally correct incoming sRGB images using either your gamma LUT settings (won’t work for procedurals) or any kind of color correct map)
This way the resulting image will be both rendered and saved linear. Everything else will simply not be linear. This is not an issue if it is what
you are after. And suits many perfectly fine. But it’s not linear.
Regards,
Thorsten
right thanks for a quick explanation!!!
ive started using BB workflow, using reinhard and building the scene up with darked colors and greyer whites and i get very few burned places…of course as bertrand saind, sometimes you just wont help it, it burns such as in real life when you take a picture…
if you follow thorsten’s steps, and save to a hdr format, you simply don’t want your output to have any gamma shift/correction applied to it, because it will be correctly interpreted as linear anyway.
you simply let vray know that you’re rendering to a file which will be linear space, that’s why is important to set the gamma at 2,2. it forces vray to consider the rendering as gamma corrected, so that it won’t undersample in areas that it would consider otherwise extremely dark and not worth spending but a few samples on. this is basically what “don’t affect colours” is useful for, correct sampling but no actual colour mapping.
