Where are the dr logs kept when running dr as a service?
Ive looked in all the usual places but cant find a dr log anywhere.
Theres also no information on where to find them on the helpdesk.
The usual place would be %userprofile%\Appdata\Local\CoronaRenderer\DrData\DrLog.txt. Since you run it as system service, the %userprofile% part is “%windir%\system32\config\systemprofile”
So all in all you should find all DrServer related files there:
"%windir%\system32\config\systemprofile\AppData\Local\CoronaRenderer\DrData"
Edit: Just noticed:
https://coronarenderer.freshdesk.com/support/solutions/articles/12000007896
See “Troubleshooting” → “2.”
Good Luck
See this is what i thought too, but i dont even have a CoronaRenderer folder in the specified location
So maybe it’s not the system user which runs the service but another? You could use basically every account to run a service. Have a look in task manager details in the row of DrServer.exe and column Username. Or look it up in ComputerManagement → Services and Applications → Services. Is it user “SYSTEM” or any other?
Good Luck
Its the administrator account and the administrator is logged in :confused: It says Administrator in the services window.
Ok, then you should find everything in Users\Admnistrator(.computername)\AppData… and so on :smiley:
Good Luck
Im being an idiot.
Its inside the dr data folder alongside all the textures. I just didnt see it as it was mixed in with them facepalm
There should not be any textures if your assets are linked correc… okok, i’ll stop ;] Good you’ve found all you need,
Good Luck
Well thats an interesting point. Why are there textures there.
Can open. Worms everywhere.
