Lately, I have been getting those little white specs in my render. The specs are in the reflections and raising the subdivs does not help. I am using IRR + LC and an HDRI. I turned on subpixel mapping and the HDRI is invisible, however, I am still getting the specs.
Ive been plagued by those a lot lately and its becoming a serious problem even with using Max Ray Intense that often doesn’t get rid of them all no matter how high or low I take the value. One thing that did work for the most part for me was in the vray material under the options tab changing the Treat Glossy Rays as GI to Always if I remember correctly.
I’ll try it, thanks![quote=“TSR_trix, post:16, topic:46616, username:TSR_trix”]
[/quote]
What kind of material do you have there? Any GGX BRDFs involved?
Yes. I use VMC to set all my materials to GGX BRDFs.
Ok. Next question: is there anisotropy involved?
I don’t think so, unless it is on by default[quote=“ACastro, post:46, topic:40412, username:ACastro”]
[/quote]
It is off by default.
Which V-Ray version is that, is Max Ray Intensity of any help?
Can you attach the scene so we could have a look what’s going on?
We won’t need the complete scene, if you could optimize it by removing all unrelated to the issue assets that would be great.
I have this a lot too. Will upload a scene one of these day.
Ill see if I can upload something as well.
-dave
Just going to post an image here before uploading the scene, maybe it’s setting related. Basically an interior with a very large window.
After 7.5 hrs hours of rendering at 4K.
Edit: might have something to do with the Mesh lights. I haven’t really tested anything as I had very little time. Those circular thingies are mesh lights with the same shape as the casing which is a refractive material with some blurry refractions.
I ended up putting a median filter in photoshop to remove those but that blurs the thing quite a bit.
Yep, that’s them! [quote=“Morbid Angel, post:15, topic:48201, username:Morbid_Angel”]
[/quote]
So is there any chance one of you might get me a scene to vlado@chaosgroup.com so that I can look at what’s causing these? Just in case it’s a bug.
I could, but someone else might a smaller file. Mine is a small space of s large model.
Well, I asked for a file months ago in another thread and still nothing, so I’ll take anything
I can get you FTP infos to upload it.
I’ll get you something later today.
This should do it. I think. MAX 2016, latest offical build.
The high noise levels comes from a few things:
1.BF settings - this is a interior scene and 32 subdivisions are just not enough.
2.Min Shading Rate - there are a lot of glossy reflections in the scene and since their materials subdivisions are too low the result is noisy.
3.Image Sampler Type - Progressive image sampler is not as effective as Adaptive one in this situation.
You could speed up the rendering and increase the image quality by tweaking the following settings:
1.Switch to IM with high preset, 75subdivs
2.set Min Shading Rate to 50
3.set IS to Adaptive with 1/12/0.01 for Min/Max/Color Threshold.
If possible try to render the scene with the above settings and let us know what is the result compared to the previews one.
As Bobby, I meet more and more often these white spots in my scenes. I notice they usually appear with the use of GGX BRDF. The subpixel mapping and the max ray intensity don’t work at all, the only way to fade them a bit is to modify the GTR Tail Falloff from 2 to 3… but otherwise nothing works (except if you clamp, but i don’t want it).On the other hand I tried presets recommended by Svetlozar but except huge rendered times, it does not work at all.
But maybe I do not use very well these new GGX shaders (the glossiness seems much more sensitive to noise than other types of BDRF …).
I will try to send you my scene in the next days.
thanks
mienda
