I just noted in the new preview version feature list (that I’ve yet to install) there are some changes to the horizon and backdrop - which has reminded me to ask (as I can’t recall having before) would it be at all possible to do away with the environment entirely?
Specifically, even with a solid-colour ground plane and/or sky map - there is still a “shading effect” across said planes - which means when wanting to only show the “model”, live, standalone or as screenshot, we can’t (as desired).
For screenshots (often destined for a report on good old boring plain white backgrounds) we find ourselves having to run around and magic-wand/lasso the building apart from shades of murky white/grey - which is a bit of a bore, (complicated by the gradations) since it’s not like we can set up the masks for re-use as we can’t ever return to the exact same viewpoint (itself a problem)
So I was wondering, can we have an option where both ground and sky planes are completely absent - and ONLY the model gets “rendered” - like how we can with, (cough) Revit already?
Does that make any sense?
