why does this happen, Prepasses
Ok so I’ve rendered out a irr map and saved it, when I go to ‘from file’ option the messenger says it has loaded the map successfully and looks like it is going to render out at the bucket stage (which is what I would expect) but it starts on all prepasses all over again, I thought this happened when materials had the ‘Use Interpolate’ option checked? any ideas,
thanks,
Tom
If You are still having problems with that, You can mail me your scene
<< nikki@chaosgroup.com >>
nikki Candelero
Sure, first I think I will try and put basic vray material on everything and hit render, and see what happens, if same I will send file,
Tom
Edit: just did that and rendered out from irr map with no problems/repeating prepasses, so hence it must be a material thing? what should I look for Nikki?
Thanks,
Tom
I can’t say for sure, but i think there should be a material, which is not in the ME… which can cause the problem… /probably ticked with <Use interoplations>/.
You can start hiding objects -one by one, until You get to the one, who is
making it… then use the Eye-dropper tool to get its material in the ME…
nikki Candelero
will do, thanks for help,
Tom
there a script on script spot for global material adjustments , ah found it
http://www.scriptspot.com/scripts/web\_upload/Metin Seven/7h_vray_automator_v1-1.zip
worked well for me the other day when i had the same problem on a consulting job i was doing.
natty, is the script also looking into Multi-Sub, Blend, Shellac, and other materials that contain more than one Mtl in them… ? 10x
nikki Candelero
Dont know to be honest you’ll need to ask Metin Seven ..
hmmmm, tried that as I already have script (but you reminded me :slight_smile: ) and still problems, am currently trying one last thing and may post scene if proplem persists,
cheers,
Tom
update, got the little Bugger, frozen obj that had it checked, sorted now , ta
