After vrscene is loaded complete , there is no printing information until noise threshold 0.2.
Are there any callback events or solutions?
V-Ray core version is 5.10.01
RenderMode RENDER_MODE_INTERACTIVE_OPTIX
You mean “after rendering is started” instead of “after vrscene is loaded complete”, I suppose. What exactly do you want to achieve? You can call VRayRenderer::getInteractiveStatistics() periodically and check the InteractiveStatistics::currentNoiseThreshold member. There is also VRayRenderer::setInteractiveNoiseThreshold(threshold) to set the target noise threshold.
If you mean that the first ProgressiveImageUpdated callback you get is after the noise threshold has already reached 0.2, it will vary because it depends on some scene settings, especially those in the SettingsRTEngine plugin.
There are (currently) no progress updates during interactive rendering. Unfortunately that includes PRODUCTION_CUDA and PRODUCTION_OPTIX modes as they use the the same rt_engine internally as the interactive modes.
