Why the gras appears plane in my renders?
Hi! Friends.
When Irendering a image thes grass appears plane, I try to chnge te displacement, aumenting the numbre an the vertical but the result its the same, how I can do to in my renders the grass appears more real, I’ts the same problem with the woodfloor. And how I can change the shadows settings to obtain the sun an shadows for a specify city?
Hola.
Cuando renderizo una imagen el pasto aparece plano, he intentado cambiar los settings del material en el displacement y en el vertical pero eso no cambia nada, como puedo hacer para que mi pasto aparezca mas real y lo mismo pasa con los pisos de madera. Y como puedo cambiar las opciones para el asoleamiento y sombras en una ciudad especifica?
Salut!
Quand je fais quelque render la pelouse semble être plaine, j’ai intenté de changer les option du displacement et vertical mais le resulté c’est le même, Comment je peux fair pour que la pelouse elle soi plus réel, c’ets le meme probleme avec le pis en bois. Et comment est-ce-que je peux changer les option pour obtenir les ombres pour une ville specifique?
Re: Why the gras appears plane in my renders?
Is the grass part of other geometry with different materials? I think I had that problem. I think I fixed it by separating the grass geometry into a completely separate component.
I had the same problem for my few projects. I try different way to create the plane and add the displacement to it. it won’t work. unless i create a small area and not in any component. the displacement will turn up. Any clue for this problem?
Give this a try: http://asgvis.com/index.php?option=com_smf&Itemid=90&topic=3550.0
It works for me…
Hi Newbie.
I chnge somethings and i separe the geomtry of the grass, and finally the grass had a displacement, but the result it was not very well, the grass appears so bad so What can I do?
I Stoped the render.
What does your VrayMtl look like in Material Studio? Something like this?
Yes my material looks like these, but in my render not appears in a good way, someone of you can expose your own settings step by step?.
I just posted an example SU file, vismat (displaced grass), and visopt (IR/LC, 640x480, Phys cam, Day time, medium quality) in a zip file to Rapidshare. That way you can see how it all works together. The download link is: http://rapidshare.com/files/95811355/grassdisplacement.zip.html
If you just extract the main directory in the zip directly to your c drive, you shouldn’t have to remap any bitmaps (i think). otherwise, everything is in there for remapping if you choose a different location. Hope that helps you sort it out! By the way, this is what the render of this little scene looks like for me:
Thanks friends I will try all the options.
Many tanks!!
Now my render looks so good!
A lot of thanks for you!
much better!! now, if you have time to wait for improved quality, try adjusting the displacement setting in your visopt to get even better looking displacement…make Edge Length(pix)=2 and Max Subdivs=512. That was my setting in my grass tests. Or, if have a really long time and , make Edge Length(pix)=1 and Max Subdivs=1024!
Also, it appears that the grass may be refracting a little too much green color on to the side of your walkway…maybe you could reduce the degree of refraction just a bit in your vismat.
hei!? I’ve downloaded the grass displacement and try it. Why is it that my render comes flat? I remap all of them and i did not change any settings, I applied what it is needed to be but still I get flat grasss image.
You must select the area to apply the grass with her edges it is a good idea convert in a group.
Good luck!
