Windows Security Updates = Broken DR
If this helps anybody - We’ve found that a recent security update has broken distributed rendering on our network. We have Windows 10 workstations and Win 7 render farm machines running Max 2017 and Vray 3.04.02
The specific updates are KB3177725 (Windows 7) and KB3172729 (Windows 10). As a side note - the same patches stopped Revit workstations being able to print.
Cheers
Thanks for sharing this info. Hope the next Windows update will fix the damages caused by this one.
Hi Tashko,
i have DR Problem too. After install Vray 3.40.2, DR will not work anymore. i am using win 10-64bit version1607 on the client and Win10-64bit version 1511 on the Renderserver.
Could be this the problem? But Before updating to 3.40.2 DR worked well, even with that different win10 version.
here is the Log from the Render Server:
is there any Solution now or Workaround? Thank you!
best regards
ptjie
Console created, V-Ray A from Jun 10 2016, 22:27:21
[2016/Aug/30|12:47:18] Scene loaded from “C:\Users\Pxxx\AppData\Local\Autodesk\3dsMax\2016 - 64bit\ENU\temp\vray_server_scene.max”
[2016/Aug/30|12:47:18] getting sequence data…
[2016/Aug/30|12:47:18] Extracting sequence data from RendParams.
[2016/Aug/30|12:47:18] Setting up V-Ray parameters for frame rendering.
[2016/Aug/30|12:47:18] Extracting sequence data from VRender.
[2016/Aug/30|12:47:18] Forcing multithreading
[2016/Aug/30|12:47:18] A render elements manager with 10 elements detected
[2016/Aug/30|12:47:18] Render element: VRayAlpha
[2016/Aug/30|12:47:18] Render element: VRayZDepth
[2016/Aug/30|12:47:18] Render element: VRayRawReflection
[2016/Aug/30|12:47:18] Render element: VRayExtraTex_vraydirt
[2016/Aug/30|12:47:18] Render element: MultiMatteElement1
[2016/Aug/30|12:47:18] Render element: MultiMatteElement2
[2016/Aug/30|12:47:18] Render element: MultiMatteElement3
[2016/Aug/30|12:47:18] Render element: MultiMatteElement4
[2016/Aug/30|12:47:18] Render element: MultiMatteElement5
[2016/Aug/30|12:47:18] Render element: MultiMatteElement6
[2016/Aug/30|12:47:18] Calling beginSeqeunce()
[2016/Aug/30|12:47:18] getting frame data…
[2016/Aug/30|12:47:18] Setting up frame data.
[2016/Aug/30|12:47:18] Extracting frame data from FrameParams.
[2016/Aug/30|12:47:18] Extracting frame data from VRender Environment params.
[2016/Aug/30|12:47:18] Extracting frame data for fields.
[2016/Aug/30|12:47:18] Extracting frame data from node (VRayPhysicalCamera001).
[2016/Aug/30|12:47:18] Rendering from camera VRayPhysicalCamera001
[2016/Aug/30|12:47:18] Setting up frame region.
[2016/Aug/30|12:47:18] frame number is 0
[2016/Aug/30|12:47:18] Calling beginFrame()
[2016/Aug/30|12:47:18] Calling renderImage()
[2016/Aug/30|12:47:18] Calling endFrame()
stuck until here, then if i cancel the DR on the client, it wrote:
[2016/Aug/30|12:48:29] Received TM_END_RENDER from 192.168.16.125
[2016/Aug/30|12:48:29] frame number is 0
[2016/Aug/30|12:48:29] frame data is NULL, aborting
[2016/Aug/30|12:48:29] Calling endSeqeunce()
[2016/Aug/30|12:48:29] Closing DR session from 192.168.16.125
[2016/Aug/30|12:48:29] warning: Failed to delete server scene file “C:\Users\Pxxx\AppData\Local\Autodesk\3dsMax\2016 - 64bit\ENU\temp\vray_server_scene.max” (0)
[2016/Aug/30|12:48:29] Broadcasting TM_SERVER_STARTED after render
i got another vrlog under %temp% , if it helps to locate the problem:
[2016/Aug/30|12:47:18] “default” preset not loaded: Cannot open file “C:\Users\Pxxx\AppData\Local\Autodesk\3dsMax\2016 - 64bit\ENU\en-US\plugcfg\vray.cfg”
[2016/Aug/30|12:47:18] Constructor entered (loading from file).
[2016/Aug/30|12:47:18] Setting default filter kernel.
[2016/Aug/30|12:47:18] Constructor done.
[2016/Aug/30|12:47:18] Loading from file.
[2016/Aug/30|12:47:18] Loading filter parameters.
[2016/Aug/30|12:47:18] Adding host “bit002”:20204 from scene
[2016/Aug/30|12:47:18] Loading done.
[2016/Aug/30|12:47:18] VRenderer destructor entered.
[2016/Aug/30|12:47:18] VRenderer destructor done.
Redirecting log file to “c:\VRayLog.txt”
“c:\VRayLog.txt” already pasted in the post above/before
I’m not sure what is the issue here and it would be a good idea to test with one very basic scene first to see if the same issue will occur. Then we will see how to proceed further.
Hi Tashko,
i am using already very basic scene. my problem is: the render server can in fact load the scene, and it starts frame 0, but i dont see any bucket of this server in the vray frame buffer. i see only the main clients buckets. sorry if i dont describe my problem well.
best regards
ptjie
new log:
[2016/Aug/30|16:03:23] Scene loaded from “C:\Users\Pxxx\AppData\Local\Autodesk\3dsMax\2016 - 64bit\ENU\temp\vray_server_scene.max”
[2016/Aug/30|16:03:23] getting sequence data…
[2016/Aug/30|16:03:23] Extracting sequence data from RendParams.
[2016/Aug/30|16:03:23] Setting up V-Ray parameters for frame rendering.
[2016/Aug/30|16:03:23] Extracting sequence data from VRender.
[2016/Aug/30|16:03:23] Forcing multithreading
[2016/Aug/30|16:03:23] A render elements manager with 10 elements detected
[2016/Aug/30|16:03:23] Render element: VRayAlpha
[2016/Aug/30|16:03:23] Render element: VRayZDepth
[2016/Aug/30|16:03:23] Render element: VRayRawReflection
[2016/Aug/30|16:03:23] Render element: VRayExtraTex_vraydirt
[2016/Aug/30|16:03:23] Render element: MultiMatteElement1
[2016/Aug/30|16:03:23] Render element: MultiMatteElement2
[2016/Aug/30|16:03:23] Render element: MultiMatteElement3
[2016/Aug/30|16:03:23] Render element: MultiMatteElement4
[2016/Aug/30|16:03:23] Render element: MultiMatteElement5
[2016/Aug/30|16:03:23] Render element: MultiMatteElement6
[2016/Aug/30|16:03:23] Calling beginSeqeunce()
[2016/Aug/30|16:03:23] getting frame data…
[2016/Aug/30|16:03:23] Setting up frame data.
[2016/Aug/30|16:03:23] Extracting frame data from FrameParams.
[2016/Aug/30|16:03:23] Extracting frame data from VRender Environment params.
[2016/Aug/30|16:03:23] Extracting frame data for fields.
[2016/Aug/30|16:03:23] Extracting frame data from node (VRayPhysicalCamera001).
[2016/Aug/30|16:03:23] Rendering from camera VRayPhysicalCamera001
[2016/Aug/30|16:03:23] Setting up frame region.
[2016/Aug/30|16:03:23] frame number is 0
[2016/Aug/30|16:03:23] Calling beginFrame()
[2016/Aug/30|16:03:23] Calling renderImage()
[2016/Aug/30|16:03:23] Calling endFrame()
[2016/Aug/30|16:05:53] Received TM_END_RENDER from 192.168.16.125
[2016/Aug/30|16:05:53] frame number is 0
[2016/Aug/30|16:05:53] frame data is NULL, aborting
[2016/Aug/30|16:05:53] Calling endSeqeunce()
[2016/Aug/30|16:05:53] Closing DR session from 192.168.16.125
[2016/Aug/30|16:05:53] warning: Failed to delete server scene file “C:\Users\Pxxx\AppData\Local\Autodesk\3dsMax\2016 - 64bit\ENU\temp\vray_server_scene.max” (0)
[2016/Aug/30|16:05:53] Broadcasting TM_SERVER_STARTED after render
i did update both all machines to windows 10 build 1607. 64 bit, vray newest 3.40.03 and 3dsmax 2016 sp3. firewall is already set to open vrayspawner. vrayspawner run as service with account permission. but DR still wont work :frowning:
bevor update to 3.40.02, DR was fine (with vray 3.30.)
Last Log from today:
[2016/Aug/30|20:17:31]
[2016/Aug/30|20:17:31] Starting DR session from 192.168.16.125
[2016/Aug/30|20:17:31] Receiving DR scene from 192.168.16.125
[2016/Aug/30|20:17:32] Resetting VRender.
[2016/Aug/30|20:17:32] Setting default filter kernel.
[2016/Aug/30|20:17:32] “default” preset not loaded: Cannot open file “C:\Users\Pxxx\AppData\Local\Autodesk\3dsMax\2016 - 64bit\ENU\en-US\plugcfg\vray.cfg”
[2016/Aug/30|20:17:32] Constructor entered (loading from file).
[2016/Aug/30|20:17:32] Constructor done.
[2016/Aug/30|20:17:32] Loading from file.
[2016/Aug/30|20:17:32] Loading filter parameters.
[2016/Aug/30|20:17:32] Adding host “bit002”:20204 from scene
[2016/Aug/30|20:17:32] Loading done.
[2016/Aug/30|20:17:32] VRenderer destructor entered.
[2016/Aug/30|20:17:32] VRenderer destructor done.
[2016/Aug/30|20:17:32] Scene loaded from “C:\Users\Pxxx\AppData\Local\Autodesk\3dsMax\2016 - 64bit\ENU\temp\vray_server_scene.max”
[2016/Aug/30|20:17:32] getting sequence data…
[2016/Aug/30|20:17:32] Extracting sequence data from RendParams.
[2016/Aug/30|20:17:32] Setting up V-Ray parameters for frame rendering.
[2016/Aug/30|20:17:32] Extracting sequence data from VRender.
[2016/Aug/30|20:17:32] Forcing multithreading
[2016/Aug/30|20:17:32] A render elements manager with 0 elements detected
[2016/Aug/30|20:17:32] Calling beginSeqeunce()
[2016/Aug/30|20:17:32] getting frame data…
[2016/Aug/30|20:17:32] Setting up frame data.
[2016/Aug/30|20:17:32] Extracting frame data from FrameParams.
[2016/Aug/30|20:17:32] Extracting frame data from VRender Environment params.
[2016/Aug/30|20:17:32] Extracting frame data for fields.
[2016/Aug/30|20:17:32] Extracting frame data from node (PhysCamera001).
[2016/Aug/30|20:17:32] Rendering from camera PhysCamera001
[2016/Aug/30|20:17:32] Setting up frame region.
[2016/Aug/30|20:17:32] frame number is 0
[2016/Aug/30|20:17:32] Calling beginFrame()
[2016/Aug/30|20:17:32] Calling renderImage()
[2016/Aug/30|20:17:32] Calling endFrame()
[2016/Aug/30|20:17:55] Received TM_END_RENDER from 192.168.16.125
[2016/Aug/30|20:17:55] frame number is 0
[2016/Aug/30|20:17:55] frame data is NULL, aborting
[2016/Aug/30|20:17:55] Calling endSeqeunce()
[2016/Aug/30|20:17:55] Closing DR session from 192.168.16.125
[2016/Aug/30|20:17:55] warning: Failed to delete server scene file “C:\Users\Pxxx\AppData\Local\Autodesk\3dsMax\2016 - 64bit\ENU\temp\vray_server_scene.max” (0)
[2016/Aug/30|20:17:55] Broadcasting TM_SERVER_STARTED after render
what does it mean? [2016/Aug/30|20:17:55] frame data is NULL, aborting
could anyone help please? thank you in advance
best regards
ptjie
That message means that the render slave is not able to load or receive the required parameters for the current rendering process. Unfortunately it is very difficult to say what exactly is the problem here without logging to this machine. So what I can recommend in this situations is to contact us via our support mail (support@chaosgroup.com) in order to arrange a remote session. You can also add a link to this forum thread.
By the way, I just did quick test to see if there are any problems with the windows 10 update KB3172729, but DR seems to work fine here.
Edit: tested on Max 2016, I will try that on 2017 as well.
Hi Tashko,
thank you for your offering. i sent an email to support. i hope they conntact me for remote session
best regards
ptjie
Thank you. We just received your mail and will reply shortly.
Hi Tashko
Thanks - that’s interesting. Perhaps in my case the problem is to do with that security patch on a Win 10 machine trying to send DR to Win 7 machines. Maybe if we had Win 10 all round things would be OK. All I know is, once we deleted the Win 10 security patch - we could distribute render once again.
Sorry I forgot to update this thread since the communication went via email.
Actually we managed to replicate the DR problem here on one workstations but we are not able to figure out what is going on yet. Machines with similar software (Windows anniversary update, which most probably includes KB3172729 patch) and hardware configurations works fine in DR renderings with build 3.4 but that one has this problem. We can’t confirm at this point that there is any connection to the Windows updates.
Hi, is there any update concering this problem ?
We are also have this issue here with DR…
Restarting the spawner service on the machine fixes it but it’s very annoying.
Thanks !
Jo
We don’t have solution for the issue described in this thread yet, but the problem in your environment may be different. What do you get in the log of the machine used to submit the DR job ?
Is it “Server “IP of the slave” Scene loaded; starting render.” and slave doesn’t join the rendering at all? Can you post the log from the slave machine?
