Maybe I have overseen it - I’m looking for a 3D noise texture which doesn’t need proper UV coordinates - for example at this implantat. Could be a great helper to see it at V-Ray.
@Micha Just use a vray noise texture and set texture coordinates to 3d world xyz
Great, I have completely overseen this option. At the help pages there can be found no word about it. Do you know - doe’s the 3D object space work too, so that objects can be animated and the 3D coordinates follow the object?
@georgi.georgiev Could be nice if the 3D texture placement could be added to the help pages.
Sure, use local xyz instead of world and it should work fine.
