Hi, we have many licenses and users. We would love to see an export/ import function for Visual settings, for easier sharing of company standard settings also in Enscape.
Or even better; possible to use a central stored template-file with all possible settings that will be read at every startup of Enscape. If changes are made in template , new settings/ config is loaded at nest Enscape startup.
Can someone make it happen in v2.7.1 (please)?
Thanks a lot for your feedback.
You are aware, that you can already export any Visual Settings you like?
Check out our dedicated knowledgebase article regarding this subject here as well.
If you still want me to file some wish of yours as a feature request please gladly let me know!
Thank you, I was not aware
Gladly let me know in case you want to share any feedback regarding this functionality in general!
The save Presets to project option, will that make it possible for other users on their own computer to open a Sketchup file with Enscape and load the presets from project? Or is this functionality only for use within same computer?
Yes to what you said first, the settings will be saved in the project itself, so you can also open it on a different machine and just load them.
