Heya
Will it work?
I fancy 2 of those in my rig… ![]()
http://www.tomshardware.co.uk/xeon-phi-larrabee-stampede-hpc,review-32565.html
Heya
Will it work?
Right away it won’t work. We would love to take a look at this, but we don’t have the card here and I don’t know how to get it.
I think Xeon Phi is an absolute must-have (provided you’re okay with only 8GB of memory of course) since it’s x86 and the power output is at 1TFLOPS. For comparison a Core i7 CPU is like 50GFLOPS “only”. One such card is like a whole render farm…
I hope that u will be able to swap data and use PC ram… or at least have 2x PHI and they could share their memory so u end up with 16 gb of ram… For me a minimum is 24 gb atm ![]()
give it a few years guys…
I see That the Phi runs on Linux. Shouldn’t this make it easy to run vray as there is already a linux version of it?
Hopefully, yes. I don’t know enough about it yet though.
Yeah looks great, but still, if your saying that 1 i7 is doing “only” 50GFLOPS, isn’t 1TFLOPS only twise the speed? So basically 2 computers, that’s not really a whole render farm…
I hope I’m wrong ![]()
And what about the new cuda 5?
I saw that :
“Direct communication between GPUs and other PCIe devices”
Does that mean that cards will be able to interact with each other and that ram could be shared between cards?
Like multiple cpu on the same motherboard share the same ram?
Stan
The difference between 50 GFlops and 1 TFlop is 20 times, not 2 times ![]()
And what about the new cuda 5? CUDA Toolkit - Free Tools and Training | NVIDIA Developer I saw that:
“Direct communication between GPUs and other PCIe devices”Does that mean that cards will be able to interact with each other and that ram could be shared between cards? Like multiple cpu on the same motherboard share the same ram?Unfortunately, no.
One, this is not an automatic process in the same way that multiple CPUs can access the same system RAM (so a programmer must do tedious bookkeeping to remember which parts of a data structure are in the memory of which device; in our case, this would mean rewriting V-Ray RT GPU from scratch and throw away all the work we have done so far). Two, it is a lot slower than accessing the RAM of the same GPU (because the PCI bus is still much slower than on-board memory).
Seems like we can put 4 xeon phi card in the same workstation
- http://www.novatte.com/products/xeon-phi/m40phi
Maybe the distributed rendering performance may be A LOT better on PCIe than on the Gygabite network.
Ah right so thats interesting… I hope you guys would find some kind of solution for that :s
as to PHI workstation do you think that memory ram could be sharable or expandable ? Its not GPU so I guess it will use Vray production render so it should be also able to access motherboard ram ? Not sure how much speed do we get from pci3 tbh I have not checked it for a while now…
As to testing PHI u can rent server from them maybe? :] http://www.novatte.com/products/xeon-phi/xeon-phi-coprocessors
Thanks, bye.
So we had a brief look at the Xeon Phi documentation; some conclusions that we can make (although of course, we need to test them with the actual hardware):
*) For the moment, only Linux hosts are supported. So forget about 3ds Max right now. Support for V-Ray for Maya, V-Ray Standalone and V-Ray RT CPU seems possible and fairly easy, using the existing framework for distributed rendering (so the card would appear as an extra host available for DR).
*) It should be possible to port the full production V-Ray; no limitations like with GPU rendering.
*) Whether the card can access directly the main RAM, I don’t know - but it can access directly files from the main machine, like textures, proxies etc.
In any case, it will take some time to research all this, so don’t expect any results tomorrow
But we will certainly look into it.
Yea babe… love u Vlado ! This is great news… waiting for further news then ! ![]()
interesting, how would this integrate into windows (not linux).?
I think it will work just fine with win maya build since there is vray for maya linux I guess… not sure gotta see what Vlado say…
Also Vlado regarding V-GPU the decision not to do it for CUDA 5 share memory is it no a bad one? I think there will be PCI4/5/6 gen which will be very fast or as fast as cpu to ram connection we have at the moment. To be left out out of the race might be a bad for Vray GPU… Other engine will probably pick it up. Iray is already doing light patch expressions to get passes out of GPU render and vray is quite quiet… I just hope you guys wont abandon the GPU version :s
thanks, bye.
We’ll see…
Iray is already doing light patch expressions to get passes out of GPU render and vray is quite quiet…And V-Ray has instances and render elements… so?
I just hope you guys wont abandon the GPU version :sAnd what if Xeon Phi turns out a better solution?
Vray rt CPU/GPU can do render elements?
did not know that one o.o
As to Phi vs gpu… true not sure what will be on top. I guess maybe thanks to PHI nvidia might lover prices on their tesla cards and become more competitive… But then again if PHI could possibly run full Vray production render then nothing beats that :o
Fingers cross for easy to adapt vray to phi if the performance will be worth it.
