Hello
So we got a scene with a carpet done in xgen. With a fairly high density I might add.
On our linux machines we get a Render Interrupted after failing to compile the geometry after a while. This also results with an exit code:0, which is a bit strange as it looks like the frame as finished on our farm, but no file has been saved. But we’ll add the render interrupted as a flag, so it will fail correctly next time.
But do you have any idea why this is not working properly on linux? It works on our windows machines. The log gives an xgen error about a vrscene created for the description I assume, but we get the same error on windows, and the render looks correct.
I’ll try to lower the density some, as I belive it will compile the geometry fine on linux then (same carpet has been rendered on linux before, but with slightly lower density).
Here’s the log for one of the linux machines if that helps. I can post a correctly working windows one too if you need that.
>>> [2016/Feb/23|05:24:36] V-Ray: Loading plugins from "//192.168.0.226/pipeline/bin/vray/builds/160123_vray_v3.15.01-b26624-nightly-maya2016_linux64/maya_vray/vrayplugins/libvray_*.so"
>>> [2016/Feb/23|05:24:36] V-Ray: 73 plugin(s) loaded successfully
>>> [2016/Feb/23|05:24:36] V-Ray: Finished loading plugins.
>>> [2016/Feb/23|05:24:37] V-Ray: Registered dynamic node vrayMultiProjection (id: 1115335/0x001104C7)
>>> [2016/Feb/23|05:24:37] V-Ray: Registered dynamic node VRayCurvature (id: 201308280/0x0BFFB878)
>>> [2016/Feb/23|05:24:37] V-Ray: Registered dynamic node VRaySkinMtl (id: 1115348/0x001104D4)
>>> [2016/Feb/23|05:24:37] V-Ray: Registered dynamic node VRayPointParticleMtl (id: 1115353/0x001104D9)
>>> [2016/Feb/23|05:24:37] V-Ray: Registered dynamic node VRayStochasticFlakesMtl (id: 1115359/0x001104DF)
>>> Error: line 1: line 1: Cannot find procedure "shaderBallRendererMenuUpdate".
>>> Error: line 1: */
>>> Error: line 1: "//192.168.0.226/pipeline/bin/vray/builds/160123_vray_v3.15.01-b26624-nightly-maya2016_linux64/maya_vray/scripts/AEvrayLightSphereShapeTemplate.mel" line 70.1: Syntax error
>>> File read in 11.4 seconds.
>>> Importing XGen Collections...
>>> Done.
>>> Result: //192.168.0.226/prod/proj55/maya/scenes/scene16.mb
>>> Warning: file: //192.168.0.226/pipeline/bin/maya/builds/maya_v2016-ext1sp5_linux64/scripts/others/makeCameraRenderable.mel line 60: Found camera renderCamShape.
>>> V-Ray: Starting render
>>> [2016/Feb/23|05:24:43] V-Ray: Exporting scene to V-Ray.
>>> [2016/Feb/23|05:24:43] V-Ray: Parsing light links time 0h 0m 0.0s (0.0 s)
>>> [2016/Feb/23|05:24:43] V-Ray: Translating scene geometry for V-Ray
>>> [2016/Feb/23|05:24:43] V-Ray: (Estimated time remaining: 0h 0m 1.6s): 11 % completed
>>> [2016/Feb/23|05:24:43] V-Ray: (Estimated time remaining: 0h 0m 1.4s): 22 % completed
>>> XGen Version: v2016-ext1sp5_linux64/plug-ins/xgen/ Build Date: Nov 30 2015 11:36:27
>>> [2016/Feb/23|05:24:44] V-Ray: (Estimated time remaining: 0h 0m 1.6s): 31 % completed
>>> [2016/Feb/23|05:24:44] V-Ray: (Estimated time remaining: 0h 0m 1.4s): 41 % completed
>>> [2016/Feb/23|05:24:44] V-Ray: (Estimated time remaining: 0h 0m 1.1s): 50 % completed
>>> [2016/Feb/23|05:24:44] V-Ray: Total time translating scene for V-Ray 0h 0m 1.4s (1.4 s)
>>> [2016/Feb/23|05:24:44] V-Ray: Rendering.
>>> [2016/Feb/23|05:24:44] V-Ray: Clearing bitmap cache memory...
>>> [2016/Feb/23|05:24:44] V-Ray: Rendering frames.
>>> [2016/Feb/23|05:24:44] V-Ray: Updating frame at time 1.00
>>> Error: XGen: Error in expression "XG_RENDER_:carpet1::vray_CacheFile". [carpet1.vrscene]
>>> Error: Prep errors:
>>> Line 1: No variable named $carpet1.vrscene
>>> [2016/Feb/23|05:48:39] V-Ray: (Estimated time remaining: 2h 8m 23.6s): 15 % completed
>>> [2016/Feb/23|05:48:39] V-Ray: (Estimated time remaining: 1h 30m 46.3s): 20 % completed
>>> [2016/Feb/23|05:48:40] V-Ray: (Estimated time remaining: 0h 54m 36.4s): 30 % completed
>>> [2016/Feb/23|05:48:40] V-Ray: (Estimated time remaining: 0h 34m 49.0s): 40 % completed
>>> [2016/Feb/23|05:48:42] V-Ray: (Estimated time remaining: 0h 23m 9.5s): 50 % completed
>>> [2016/Feb/23|05:48:42] V-Ray: (Estimated time remaining: 0h 15m 57.7s): 60 % completed
>>> [2016/Feb/23|05:48:43] V-Ray: (Estimated time remaining: 0h 6m 47.5s): 77 % completed
>>> [2016/Feb/23|05:48:43] V-Ray: (Estimated time remaining: 0h 5m 28.3s): 81 % completed
>>> [2016/Feb/23|05:48:44] V-Ray: (Estimated time remaining: 0h 2m 34.3s): 90 % completed
>>> [2016/Feb/23|05:48:44] V-Ray: Total time updating frame 0h 23m 59.3s (1439.3 s)
>>> [2016/Feb/23|05:48:44] V-Ray: Preparing renderer...
>>> [2016/Feb/23|05:48:44] V-Ray: Using Intel Embree ray server
>>> [2016/Feb/23|05:48:44] V-Ray: Preparing scene for rendering...
>>> [2016/Feb/23|05:48:44] V-Ray: Creating bitmap manager
>>> [2016/Feb/23|05:48:44] V-Ray: 11 lights found.
>>> [2016/Feb/23|05:48:44] V-Ray warning: Light cache leak prevention is enabled; it is recommended to turn on light cache prefiltering.
>>> [2016/Feb/23|05:48:44] V-Ray warning: Subpixel color mapping is on: rendered result may have incorrect brightness.
>>> [2016/Feb/23|05:48:44] V-Ray: Max ray intensity is enabled: rendered result may have incorrect brightness.
>>> [2016/Feb/23|05:48:44] V-Ray: Preparing scene for frame...
>>> [2016/Feb/23|05:48:45] V-Ray: Compiling geometry...
>>> [2016/Feb/23|05:50:49] V-Ray error: Exception [module=1] : Compiling geometry
>>> [2016/Feb/23|05:50:49] V-Ray: Number of raycasts: 0 (0.00 per pixel)
>>> [2016/Feb/23|05:50:49] V-Ray: Camera rays: 0 (0.00 per pixel)
>>> [2016/Feb/23|05:50:49] V-Ray: Shadow rays: 0 (0.00 per pixel)
>>> [2016/Feb/23|05:50:49] V-Ray: GI rays: 0 (0.00 per pixel)
>>> [2016/Feb/23|05:50:49] V-Ray: Reflection rays: 0 (0.00 per pixel)
>>> [2016/Feb/23|05:50:49] V-Ray: Refraction rays: 0 (0.00 per pixel)
>>> [2016/Feb/23|05:50:49] V-Ray: Unshaded rays: 0 (0.00 per pixel)
>>> [2016/Feb/23|05:50:49] V-Ray: Number of light evaluations: 110327292000 (6338.21 per pixel)
>>> [2016/Feb/23|05:50:50] V-Ray: Number of intersectable primitives: 604757
>>> [2016/Feb/23|05:50:50] V-Ray: SD triangles: 604757
>>> [2016/Feb/23|05:50:50] V-Ray: MB triangles: 0
>>> [2016/Feb/23|05:50:50] V-Ray: Static primitives: 0
>>> [2016/Feb/23|05:50:50] V-Ray: Moving primitives: 0
>>> [2016/Feb/23|05:50:50] V-Ray: Infinite primitives: 0
>>> [2016/Feb/23|05:50:50] V-Ray: Static hair segments: 0
>>> [2016/Feb/23|05:50:50] V-Ray: Moving hair segments: 0
>>> [2016/Feb/23|05:50:51] V-Ray: Total frame time 0h 26m 6.3s (1566.3 s)
>>> [2016/Feb/23|05:50:51] V-Ray: Cleaning up bitmap manager
>>> [2016/Feb/23|05:50:51] V-Ray: Total sequence time 0h 26m 6.8s (1566.8 s)
>>> [2016/Feb/23|05:50:51] V-Ray: Render interrupted
>>> [2016/Feb/23|05:50:51] V-Ray: ========================
>>> [2016/Feb/23|05:50:51] V-Ray: Clearing exporter memory...
>>> [2016/Feb/23|05:50:52] V-Ray: Total time clearing exporter memory 0h 0m 1.0s (1.0 s)
>>> Scene //192.168.0.226/prod/proj55/maya/scenes/scene16.mb completed.
Thanks in advance,
Simon
