zoooming of hdri map /aka skybox/
it happen to me sometimes ,
hdri is not in scale in conparison with my model /which is made in real units /
is it possible to do some slider to change fov of sky box map only ?
Classic issue :wink:
Sky box scaling
ok but i want to be adjustable
is it possible or not ?
Not, I think impossible.
It would be nice if there are functions that we can scale, rotate or move HDRI environment. They should have.
For one thing we have the option to rotate the sky map image under Athmosphere > Horizon > Rotation.
For the two other options, that kind of does not work with sky maps, it is just a 360 degree picture. To try our what scaling would do you can use the field of view slider. That is the max you can do with a sky map. The problem is, if the background is at a different field of view than the geometry, you will have it move at different speed when moving and it will just look broken and disorienting.
The best option is to either get a sky map that is at the elevation you require or obfuscating the horizon with context.
