Does not render invidual frame #
  • Does not render invidual frame #
    I am rendering still images, not animations. I often change the position of the sun between different camera views. For instance I render Frame 0 for late morning sun position. Then I move the time slider to Frame 10 and key frame a new "afternoon" position for the sun. I render Frame 10 with sun moved to afternoon position.
    In the past, using chaos cloud with 3DS MAX 2023, if I had the time slider at Frame 10 and submitted the job to chaos cloud it would render with the sun in the position set at at Frame 10.
    Now when I do this in Chaos Cloud, no matter what try, it is always rendering with sun in Frame 0 position.
    Also, before submitting to Chaos Cloud I us the Cloud "Preview" and that renders with the correct Frame 10 sun position. But, as stated, when I submit the job to Chaos Cloud it renders as sun at Frame 0 position.
    It seems Chaos Cloud, suddenly, will not and does not render an individual frame correctly.
    What am I doing wrong? Please help, I need help ASAP.
    Thank you.
    mark f.
    openrangeimaging.com
    Max 2025.2 | Vray 6 update 2.1 | Win 10
    Core i7 6950 | GeForce RTX 2060 | 64 G RAM
    Here are two screen grabs showing what I mean.
    mark f.
      Hi OPEN_RANGE
      You can set frame 10 to render from the Render Setup > Common tab > Frames for the time being. We'll have a look and see if we can make sure to take the time slide into account when submitting jobs to Cloud - thanks for raising the flag! Will let you know as soon as there is an update on the matter.
      Nikoleta Garkova | chaos.com
        Thank you Nikoleta. Please do let me know when this has been updated. Thanks!
        mark f.
          We've fixed the issue and builds are updated - you can download them directly from here.
            Wow. Fastest fix ever! Thank you and especially thanks for following up with notice of the fix.
            mark f.
