I am rendering still images, not animations. I often change the position of the sun between different camera views. For instance I render Frame 0 for late morning sun position. Then I move the time slider to Frame 10 and key frame a new "afternoon" position for the sun. I render Frame 10 with sun moved to afternoon position.
In the past, using chaos cloud with 3DS MAX 2023, if I had the time slider at Frame 10 and submitted the job to chaos cloud it would render with the sun in the position set at at Frame 10.
Now when I do this in Chaos Cloud, no matter what try, it is always rendering with sun in Frame 0 position.
Also, before submitting to Chaos Cloud I us the Cloud "Preview" and that renders with the correct Frame 10 sun position. But, as stated, when I submit the job to Chaos Cloud it renders as sun at Frame 0 position.
It seems Chaos Cloud, suddenly, will not and does not render an individual frame correctly.
What am I doing wrong? Please help, I need help ASAP.
Thank you.
Thank you.
