Mr.Max Sketchbook (Updated)
  • Mr.Max Sketchbook (Updated)
    Hi everyone
    I thought I would start new topic for my random sketches and hopefully this time I will be more active. the target is to get one project per week if possible so finger crossed
    N001_ You are not alone
    This one is based on an image I've seen on Instagram by Erick Ramirez @r4s .
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
    I like the "Sketchbook" idea, it is encouraging Nice render, reflection on the asphalt draws nicely viewer's attention. Looking forward to see more! Good luck!
    p.s your lucky 777th post
    My Artstation
    Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -
    Sun Tsu
      hehehe I didn't notice that triple 7 ! this topic seems promising then
      And Thanks! I'm glad you like it
      doing side personal projects even if it is just one night sketch is always fun and refreshing .I will try to keep it going : ))
      btw I did post a break down for this one here if anyone is interested
      https://www.behance.net/gallery/9023...lone-%28CGI%29
        Nice as always.
        AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
        2D | 3D | web | video
        jiri.matys@gmail.com
        https://gumroad.com/jirimatys
        https://www.artstation.com/jiri_matys
        https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
        https://www.instagram.com/jiri.matys_cgi/
        https://www.behance.net/Jiri_Matys
        https://cz.linkedin.com/in/jiří-matys-195a41a0
          N002_ Animated Tree
          I thought one project per week would be possible but it seems it is going to be one project per month : ))
          Anyway here is a fun little animation I did few nights back based on Roger Kilimanjaro work.
          the lighting and materials are pretty basic in this one as my focus was on the animation itself .
          I've used tyFlow for the wood debris/Sawdust , the spread of the green part of the tree, and the bulbs with the rope that connect them .
          the transformation at the start was done using Shape Boolean with Lathe .
          rendered using Vray Next GPU / CPU .
          I hope you like it
            Originally posted by M.Max View Post
            N002_ Animated Tree
            Tell me about it I constantly have a problem to let go some project as there is always so much space for improvements and lack of time and energy often being main issue. Though, I believe consistency is the most important thing of all, those small steps we take every day
            Geat animation, color palette, pacing, lighting - all works well together! Well done
            My Artstation
            Sun Tsu
              Thanks Karol!
              Yes, being a perfectionist myself I find it hard to call a project done ..to overcome this, I do these one night projects that whatever I can get I move on with .
                Very cool
                  Originally posted by fixeighted View Post
                  Very cool
                  Thank you !
                  003-Random tech
                  This month project is pretty simple, just a cube with Jsplacement Texture ,I've used the output map to take small range of the texture and use it for self-illumination slot .
ID:	1063654Click image for larger version
Name:	random breakdown.JPG
ID:	1063663 and here is additional one with displacement Click image for larger version  Name:	random 3.jpg Views:	1 Size:	1.54 MB ID:	1063659
                      Brilliant Navras
                      Martin
                      http://www.pixelbox.cz
                        Very disco-Borg, those bottom 2
                        Thanks for the llink.
                          Thanks !
                          it is really fun to play with this software .
                          it is like Greeble plugin but as a texture and more shapes /settings
                          speaking of Greeble, Tom mentioned that he is working on an update for it , hopefully we can do similar things with it then =D
                          Originally posted by PIXELBOX_SRO View Post
                          Brilliant Nawras
                          Thank you Martin !
                          Glad you like it : ))
                          Originally posted by Jiri.Matys View Post
                          Nice as always.
                          Sorry, I've missed your comment
                          Your tests made me jealous, so I started this one =D so thank you : ))
                            003.5 Snow ball shader
                            Fully procedural snow shader using ALSurfacemtl and couple of shiny masked Vraymtl to add the reflected speckles.
                            (for the ground I've used additional bitmap to add some foot print tho .)
                            my client liked the snow shaders that I did for fun 2 years ago with corona renderer, but he wanted it for a V-Ray project so I think this one could be considered half-personal /half commercial .
                            so I will just through it here : ))
                            I might share this one once I test it in the real project to see how it will works and if any tweaks are required .
                            The corona one is here in case someone want to try it :
                            https://www.behance.net/gallery/6442..._Free-Download
                            • #15
                              Cool (intended )
