Living and dining | Vray 6
  • Living and dining | Vray 6
    Yet another classic living and dining for a new client, I know many won't like the style but I only do the render
    Some general view plus some detail:
ID:	1161989 Click image for larger version
ID:	1161988 Click image for larger version
ID:	1161990 Click image for larger version
ID:	1161992 Click image for larger version
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
    A few more views:
ID:	1161996 Click image for larger version
ID:	1161994 Click image for larger version
ID:	1161995 Click image for larger version
ID:	1161997 Click image for larger version
      They're a bit grey and empty...needs more gold I think, just to brighten things up
      Apart from that they are of course very well done
        It must be new money; it is only 14 karate. Great detail. What are your render times?
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090 X2
        • ​Windows 11 Pro
          Im guessing your clients pay well
          e: info@adriandenne.com
          w: www.adriandenne.com
            Hi Bobby, here are some statistics, including render time:
            -about 40million polygons plus render instances
            -over 250 lights(spherical, ies, and mesh light plus a physical sun/sky for the day light views)
            -large use of Vray Fur coupled with Vray Hair material for the carpet. The area was quite large (about 250 square meters of carpet) but thanks to ^Lele^ I've managed to limit the RAM consumption by using the dedicated level of detail feature, amazing!
            -I've used C4D R26, Vray6, Marvelous Designer, all modeled by me except for some laser scans
            -most textures and shaders created from scratch for this project, I've also used a few metal from my bundle
            -tone mapping and post production done 99.9% inside the frame buffer, just some highlights compression, a LUT, and some cryptomatte mask here and there, some white balance when needed
            -10 days of work including render time
            -about 4/5h per image @4K resolution on an old 8core system
              Thanks
              Believe me or not this scene materials should have been much more rich, but the client saw some early render tests with a white override material, he like the images so much that have decided to keep them "simpler".
Name:	BAH 5161 sitting G06 test8.jpg
ID:	1162036 Click image for larger version
Name:	BAH 5161 sitting G06 test2.jpg
                Real lovely work and the render times seem fair.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Yeah those white versions are rather classy....got a 2001 A Space Odyssey vibe to them
                  I did notice the carpet and thought how nicely that was realised...makes all the difference.
                    For the same client I've worked a lot with carpets, so I've experimented a bit with Fur and Hair shader, I've got interesting results.
                    Here are a couple tests for other rooms:
                    Click image for larger version  Name:	carpet test.jpg Views:	0 Size:	1.24 MB ID:	1162062 Click image for larger version  Name:	test fur3.jpg Views:	0 Size:	661.2 KB ID:	1162063 Click image for larger version  Name:	test fur4.jpg Views:	0 Size:	309.8 KB ID:	1162064
                      Haha, okay.
                      The carpet close-ups look fantastic! The length of the strands is driven by a map to get the nice embossed look?
                        The carpets are native hair and fur? Do you have a quantum computer or do you use black magic? Edit: sorry I now read your post explaining it was VrayFur. Still, last time I tried, it was extremely slow. Isn't ForestPack better for this than?
                        A.
                        www.digitaltwins.be
                          You guys rule
                            Thanks Rick!
                            • #15
                              I’m on C4D so we don’t have Forestpack, we do have other scattering solutions but I think Vray fur works perfectly for this and it’s very easy to customize. Vray hair next shader is very fast too, and gives a nice soft look, I’ve tested also other shader setup for this but in the end hair next works better.
                              I’ve managed to get the whole scene done within 32GB of RAM.
