Living and dining | Vray 6
  • #16
    Originally posted by kosso_olli View Post
    Haha, okay.
    The carpet close-ups look fantastic! The length of the strands is driven by a map to get the nice embossed look?
    Yes a simple map in the length slot, I found a good technique for creating the map, probably it can be done with a single PS action, maybe I’ll do a tutorial in the future.
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
    • #17
      The carpet is really fantastic!​
      • #18
        Man these carpet close-ups are mind blowing. Fantastic job
        • #19
          Thanks!
          Here is another carpet test for another room, I've used a semi-procedural map for bending the fur to get a used look:
Name:	test carpet dressing.jpg
          • #20
            amazing work !
            • #21
              Originally posted by sirio76 View Post
              Hi Bobby, here are some statistics, including render time:
              -about 40million polygons plus render instances
              -over 250 lights(spherical, ies, and mesh light plus a physical sun/sky for the day light views)
              -large use of Vray Fur coupled with Vray Hair material for the carpet. The area was quite large (about 250 square meters of carpet) but thanks to ^Lele^ I've managed to limit the RAM consumption by using the dedicated level of detail feature, amazing!
              -I've used C4D R26, Vray6, Marvelous Designer, all modeled by me except for some laser scans
              -most textures and shaders created from scratch for this project, I've also used a few metal from my bundle
              -tone mapping and post production done 99.9% inside the frame buffer, just some highlights compression, a LUT, and some cryptomatte mask here and there, some white balance when needed
              -10 days of work including render time
              -about 4/5h per image @4K resolution on an old 8core system
              Are you using brute force + light cache?
              Jackie Teh
              3ds Max 2023, V-Ray 7 [7.00.05 build 32980]
              AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
              Website: https://www.sporadicstudio.com
              Email: info@sporadicstudio.com
              YouTube: https://www.youtube.com/c/SporadicStudio
              • #22
                Yes, Vray for Cinema4d do not offer Irradiance map anymore, regardless I would not use anything else than Brute force.
