Just for fun
  • #61
    my bad got it working .thanks paul
    www.kobo9.ch
    • #62
      Visible Caustics?
      Hi Vlado,
      Is there any way to view the caustic photons that aren't contacting surfaces, the same way you can view an irradiance map using imapviewer?
      Thanks,
      Nathan.
      • #63
        No, currently there is no way to do that. I have it noted though, so hopefully it will be implemented at some point.
        • #64
          Visible caustics
          Would there be any basic way to extract a txt file or something with the xyz of each photon.. or would that just be painfully huge?
          Thanks again,
          Nathan.
          • #65
            Well if you email me to vlado@chaosgroup.com I can get you the format of the .vrpmap files.
            • #66
              Hi !
              Here's my little contribute to this thread...
              Only direct caustics here using the "renderers.current.caustics_showCalcPhase=true " method.
              don't render final image is ON. Only Photon pass.
              - 1 light - 12000 photons fired
              - 15min rendertime on Q6600@3.2 Ghz - Vray 1.5 SP3)
              - render at 1600*2133 then half downsampled in photoshop to remove some grain.
              The atomic caustics mushroom :
              I've some little questions though :
              - Wich caustics parameters are involved (or not) with this method ?
              - Why the CPU is almost 70% while computing ? does i have to force system_numthreads to 4 yo get a full 100% computing ?
              Awesome tip anymay, i'll continue to play with !
              trying actually to make godrays with volumetric clouds... no chance for instance.. is it possible to combine 2 different environementfog in sp3 ? (i'll made a new thread for that if you think it's necessary
              Jérôme Prévost.
              SolidRocks, the V-Ray Wizard.
              http://solidrocks.subburb.com
              • #67
                That looks really cool. Reminds me of something you'd see done in AE.
                • #68
                  Cool effect Jérôme
                  b
                  Brett Simms
                  www.heavyartillery.com
                  e: brett@heavyartillery.com
                  • #69
                    that is awesome.
                    So beautiful, look slike a painting.
                    what kind of geometry is producing it?
                    Reflect, repent and reboot.
                    Order shall return.
                    • #70
                      thanks !
                      nothing complex here.. just started with the "volumetric caustics scene" found on www.spot3d.com Vraydoc site (see examples : EnvironementFog page).
                      Just replaced the VraySphere with a standard sphere sliced by some boxes (proboolean) and playing with nurms subdivs... you can try with any object ! torus, knot, teapot, ... the main parameter for color is the material refract fog color. The camera is a close look to the caustics on the vrayplane. all the rest is random... and a little bit of photoshop (levels/lum-contrast)
                      That's the magic part : Vray did 99.9% of this pic ! and each try gives unique results... coooool !
                      Jérôme Prévost.
                      • #71
                        That "atomic caustics mushroom" looks awesome
                        • #72
                          I dont understand...i have caustics turned on and im using irrmap/lightcahce. Ive also the show calc of caustics by using "renderers.current.caustics_showCalcPhase=true ", but im not seeing anything...
                          Regards
                          Steve
                          My Portfolio
                          • #73
                            i've not yet been able to see any form of caustic, it defeats me every time
                            WerT
                            www.dvstudios.com.au
                            • #74
                              try to see my old videotutorial
                              Hope can help you
                              bye bye
                              www.francescolegrenzi.com
                              VRay - THE COMPLETE GUIDE - The book
                              Corona - THE COMPLETE GUIDE - The book
                              --- FACEBOOK ---
                              • #75
                                Thanks very much...this looks very helpful.
                                Regards
                                Steve
                                My Portfolio
