What is the best way to get rid of noise in the shadows? This file was a bear... I had lots of problems with MAX 9. Most of the problem was layers. I had a deck in the back that wouldn't take on any materials. I ended up rebuilding the deck thinking it would solve the issue, but it didn't go away. I quickly realized the only thing the same would be the layer so I copied everything to a new layer and everything was fine Same issue with the grass. I thought I would post that info just incase someone else experiences the same problem.
