Shadow Noise
  • #16
    Crank up the sunlight i reckon. Its abit to weak.
    Needs a dash more contrast.
    Nothing you cant fix in PS.. perhaps using my S curve color correction.
    • #17
      This is the S curve color correction (albeit a very faint S)
      It often does wonders for LWF renders and renders that lack contrast.
      Move the points around a little to get a nice result. (the top point should move up and to the left while the bottom point should be moved down and to the right.)
      Ideally try and fix as much as you can in max to save need to do any post work.
      Some info on it and results here
      http://www.chaosgroup.com/forum/phpB...ighlight=curve
      • #18
        Noise
        I see... I though you had a utility. I have played with PhotoShop's S-curve, but never used it in pratice. I'll play with it some more.
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090 X2
        • ​Windows 11 Pro
        • #19
          Nice Rendering!
          Mike Henry
          http://mhenry.cgsociety.org/gallery/
          • #20
            I tried it out on your image and got rather nice results.. Just need a tweak of B&C and H&S and it was looking alot better IMO.
            • #21
              noise
              can you post it?
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #22
                Sure thing.
                Just a quick 30second jobbie.
                Basically S curve, then Shadow/Highlight to light up the shadows a touch and lowered the saturation a little.
                Certainly not perfect, but if you compare your original render and this one it looks like a huge amount of gray has been removed from the image.
                • #23
                  Gr8 improvement!
                  Good work there Daforce with tha S(uper)-curve!
                  Nuno de Castro
                  www.ene-digital.com
                  nuno@ene-digital.com
                  00351 917593145
                  • #24
                    • #25
                      noise
                      better, much better!
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • #26
                        No Noise
                        Here is an updated update.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                        • #27
                          gr8 improvement congrats!
                          just minor adjustments now...
                          like the lack of bump/displace on those bricks the reflections on the SUV...the way ur road ends/ begins the grass...well i m just getting really picky now!
                          good work!
                          Nuno de Castro
                          www.ene-digital.com
                          00351 917593145
                          • #28
                            Wow, major improvement! I do, however, agree with ene.xis on the avalanche reflections. I really like the overall mood of the lighting.
                            • #29
                              Noise
                              Ya I was going to remove the truck, but that is the owners truck. I'll have to work on it. I also agree with the pavement meeting the grass... any suggestions? I was thinking about pebbles and rocks. I added a vraydisplacement on the bricks, but maybe a bump map will add some depth. Thanks for the comments.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #30
                                your truck and tree trunks got worse IMO, but the rest got better. Add some bump to your pavement the specular is too perfect.
