DreamScape water with VRay translucency
  • #31
    You need the latest Divx codec.
    Torgeir Holm | www.netronfilm.com
    • #32
      this looks great. anyway that I can get my hands on the max file???
      I'd like to pull it apart and poke it with a stick.....
      thanks
      Matt
      • #33
        Vlado, that's both astonishing and gorgeous.
        Peter
        • #34
          does anybody has the max file?
          it would be nice, if I could get it, too!
          I have to render a scene with a lake in front of a house...
          it would help me if I could have a look to the max scene.
          thanks in advance
          themaxxer
          Pixelschmiede GmbH
          www.pixelschmiede.ch
          • #35
            im not 100% sure but I think you will need the dreamscape to see it
            • #36
              help
              hi vlado,
              i am working on a scene that needs realistic water in the same way you did this one.
              i got it to work but the nice crispy reflections were gone. it rather looked like gel. could i have a max file where it has the same setup as your avi or a explenation on how to get it to work properly.
              my background pic can be seen right trough the sea wich has rather weird effect.
              email nielssinke@hotmail.com
              with kind regard,
              Niels
              • #37
                Great Water Vlado, can you send me the max file??? thanks, my email is guca@3dluvr.com
                http://guca.cgsociety.org/gallery/
                • #38
                  what do you need the max scene file for? He posted the material settings. Its so simple it took me like 15 mins to recreate it, ooh and aah and then move on.
                  • #39
                    i still cant get this translucency thing... why not only setting the fog color and multiplier dont help... that will give the effect of falloff... i really cant understand the translucency efect here.. can someone teach me please.. thanks.
                    • #40
                      please i need answer... thanks.
                      • #41
                        Fog is absorption (makes darker with distance), while translucency is sub surface scattering. SSS doesnt' necessarily make things seen through it darker, but does make them more diffuse with distance. You often see both effecs combined, but they are not the same.
                        If you only used fog the objects below the surface would still look sharp and be visible until you reached black. Like an object in a clear colored liquid. Using translucency lets you create the more murky, particle filled, harbor water/hudson river look.
                        • #42
                          well. i see what you mean now.
                          but i feel like you are talking about something like fog with glossy refraction. Or am i understanding wrong.
                          fog with glossy refraction, is nto enough?
                          what is the actual effect that is coming from translucency?
                          Thanks alot for the description.
                          • #43
                            Two differences:
                            1. Fog alone always makes the volume darker, but translucency can make the volume brighter in areas because the light is scattered inside the volume.
                              Think of it like this: fog absorbs light while translucency spreads it around. And you can use the two together as well.
                            2. Glossy refraction occurs at the surface (for instance sand blown glass), while translucency happens inside the volume (like in wax, or orange juice). But you are right, they might look very similar sometimes.
                            • #44
                              thanks egz,
                              this helps me to get it.
                              • #45
                                i dont understand one thing,
                                i was never able to get the water as bright as in this videos.
                                it is always very dark, almost black, even after playing with the translucency depth. i also considered the "dont-use-255-white" bug.
                                when i use exposure, the objects turn very bright, and the water looks washed out.
                                if anyone can supply me with a scene file i would be very greatful.
                                Marc Lorenz
                                ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
                                www.marclorenz.com
                                www.facebook.com/marclorenzvisualization
