Hello,
I'm having alot of difficulty rendering my alley scene. Attached is a wire of the final render. Viz will lockup about 3/4 through the first irradiance pass. The scene has 660,000 polys. My next heaviest scene has just over 300,000 polys and I can render it without any problems, irradiance calc in 2 mins and it renders in 1.5 mins.
I am wondering why I am having this problem when the alley scene is approximately double the poly count of a scene that renders with ease. My vray settings in the alley are simple: 1st GI bounces:1, Secondary bounces: .8, Environment set to override Viz's @ .23, Very low irradiance map.
I let it run overnight to see if it was just taking alot longer than usual, but it was still frozen 3/4 through the firts pass. When monitoring my processors, I notice they are only being used at 50% & Memory usage is way below capacity.
I was using the free version with no luck and then switched to the demo version...same problems
Dual AMD 1.3 Ghz
512mb RAM
Any suggestions are apprecieated.
much thanks
Joe P.
Dual AMD 1.3 Ghz
512mb RAM
much thanks
Joe P.
