Found it! - Boundary Clipping = Edge.
UK Mansion
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostIt's kind of working
[ATTACH=CONFIG]21893[/ATTACH]
Some strange Ambient Occlusion stuff going on (vrayextratexure)
[ATTACH=CONFIG]21894[/ATTACH]
Basically Edge mode works as Point mode but removing elements at edge.
Regarding the Ambient Occlusion issue, i must ask to Vlado. It seems some trimmed elements are visible for the GI.
Originally posted by glorybound View PostSome strange Ambient Occlusion stuff going on (vrayextratexure)
Perfect, thanks!Originally posted by Itoosoft View PostWe got the reply from Vlado regarding this issue: you must turn on "work with transparency" in VRayDirt. That solves the problem.Bobby Parker
phone: 2188206812
- Windows 11 Pro
To Itoo:
Thank you thank you thank you. Seems to work great. Finally a good working lawn system. Keep up the awesome work.
Feature request:
If i have an AutoCAD file with 10 tree block symbols and then file-link them into max, i can use the Custom Edit feature to assign a ForestPro tree to each block. But, if i edit the base autoCAD file and copy some of those blocks so i then have say 15 instances of them, i would LOVE it if forestpro could automatically add the forestpro trees to the additional 5 instances. Make sense? Basically a smarter 'linking' between an autocad file and forestpro.
I bet lots of people would love that! Can it be done? Maybe add a button in ForestPro?
Cheers!- Dual 3.47 ghz Hex Core Xeon CPUs; 96GB Ram; SSD Drive; 3dsMax 2020; V-Ray; Sketchup 2020
- Love these Plugin/Scripts: ForestPro, RailclonePro, Soulburner, Populate Terrain
Feature request:
Cheers!
Regarding your suggestion, this is something we have considered but although would be possible a smart link with the referenced objects, it's not clear how to import new elements. I mean, it would be necessary some rule to find them: by name using wildcards ?, some type of container in AutoCAD ?. Probably each user would like to use their own method.
If you want to discuss it, your ideas are welcome in the iToo forum (we are a bit off-topic here).
how about if the blocks in autocad have the same name as the trees...so the trees would match the location of the block automatically.
or matching autocad block name with a Forest Pack so one can use a set of trees for the same block in cadLast edited by flino2004; 28-11-2014, 07:32 PM.show me the money!!
Unfortunately, it didn't help.Originally posted by Itoosoft View PostWe got the reply from Vlado regarding this issue: you must turn on "work with transparency" in VRayDirt. That solves the problem.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Double checked and I didn't have it checked. I'll check it and report back later.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Awesome! Problem solved. Thank you!Bobby Parker
phone: 2188206812
- Windows 11 Pro
I used a Forest Pro preset, with the new "edge" selected. It was rather simple.Originally posted by arqestevez1 View PostIt's great!
May i ask for some directions...
I'm about to start a project with a lot of grass. Yours is looking great, is there any tutorial you could recomend?
Thank you in advance!Bobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
