Originally posted by hoppergrass
View Post
1234 State Parkway
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
It's the problem that the refractive glass is sending rays into a hall of mirrors and seeing all sorts of things off camera - glass is a bastard, glossy glass even worse
Looks great with the dof, glare / glow too high - having a flare coming off a tulip seems a bit odd
I use Looks in PS.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Good eye. I did catch that, but simply ran out of time to work on it. I was going to drop a header in, but I figured the header would be buried in the floor system, so I just left it alone.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Looks gorgeous - small bit of dof needed on the garden outside in both though, if you've got shallow focus on the fg, there should be some on the bg too - it'll make the outside less distracting too.
Great work, you're getting really consistent!
Originally posted by joconnell View PostLooks gorgeous - small bit of dof needed on the garden outside in both though, if you've got shallow focus on the fg, there should be some on the bg too - it'll make the outside less distracting too. Great work, you're getting really consistent!
Bobby Parker www.bobby-parker.comBobby Parker
phone: 2188206812
- Windows 11 Pro
Looks good, though for my opinion this interior needs completely different lighting. I think here you need to focus more on the kitchen itself , but on the first image for example your focus goes on bright areas. Also i think that kind of kills perspective , you do not sense the air , depth is not that obvious. What i'd do is i'd remove all artificial lighting and start with making balances outside / sky / hdri lighting. After that i would add subtle lighting over the middle island to define the working area and making that important spot of the image. The first plan i would make subtle lit - i like how it looks on the right , i think that's the correct brightness for closest part of the image. Anyway that is only my opinion , who knows what client wantsAvailable for remote work.
My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
Originally posted by Oleg_Budeanu View PostLooks good, though for my opinion this interior needs completely different lighting. I think here you need to focus more on the kitchen itself , but on the first image for example your focus goes on bright areas. Also i think that kind of kills perspective , you do not sense the air , depth is not that obvious. What i'd do is i'd remove all artificial lighting and start with making balances outside / sky / hdri lighting. After that i would add subtle lighting over the middle island to define the working area and making that important spot of the image. The first plan i would make subtle lit - i like how it looks on the right , i think that's the correct brightness for closest part of the image. Anyway that is only my opinion , who knows what client wants
phone: 2188206812
- Windows 11 Pro
Okay, I am trying to render this out with just an HDRI, but man let me tell you, getting rid of noise is a lot harder. To get rid of noise I have to increase most all settings, which increases render times. Now, if it's work it okay; we'll seeBobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostJust daylight... Looks good, however, it took 32 hours to render. I am thinking that DOF + DE isn't a good combination, especially with the crystal chandelier.
[ATTACH=CONFIG]26805[/ATTACH]
Looks awesome though.
Also - prefer the flat version, think it's more photographic personally - a very white kitchen is going to bounce a lot of light and rob contrast from the image but it's no bad thing imo, they're naturally very "airy".Last edited by joconnell; 05-11-2015, 09:30 AM.
