1234 State Parkway
Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
Originally posted by glorybound View PostI am trying your scene, but I changed to IRR low/100-50 and changed the output to 4k, which is the final delivery.Dmitry Vinnik
ShowReel:
I see, I would have never thought to uncheck those.Originally posted by Morbid Angel View Posthere is how that card was coming in when I opened your scene. Self illum material + generate gi = it emits gi in the scene.
[ATTACH=CONFIG]26851[/ATTACH]Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
would you recommend BF?Originally posted by Morbid Angel View Postthe sampling might be too extreme if you dont use brute force, irmap could get away with much less.Bobby Parker
phone: 2188206812
- Windows 11 Pro
My experience with brute force is the initial buckets just sit there for about 10 minutes, which is about the time I give up and go back to what I know.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostMy experience with brute force is the initial buckets just sit there for about 10 minutes, which is about the time I give up and go back to what I know.
Literally if you render with -3/0 100/50 for example you get very good gi solution noise free. Not happy about the precision ? set it to -3/1 then you get even higher res irmap.Dmitry Vinnik
ShowReel:
- Likes 1
I installed the latest VRay, using your setting, other than changing it to IRR, and it's on pass 4 of 4 and it's been 2hrs. I'll see what happens when it gets to the renders part, but as of now, way too long.
Bobby Parker www.bobby-parker.comBobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
yeah you might need to drop the dmc settings as I was using them for brute force cleaning up its samples.Dmitry Vinnik
ShowReel:
I usually start with 2/16 - good start?Bobby Parker
phone: 2188206812
- Windows 11 Pro
yeah its what I start with and usually land on something like 2/24 depending on a scene. In your scene the main cause of noise was brute force and no other way to clean it up other then raise max subdivs.Dmitry Vinnik
ShowReel:
I did some region renders and 1/4 does just fine. I did a series of 10 images, all 4K in under an hour, and all using 1/4 with a low IRR. Then, once in a while, I get tripped up by scenes like this.Bobby Parker
phone: 2188206812
- Windows 11 Pro
yeah quite honestly I'm not sure what it is, but even irmap I have to set waaay high to get it clean much higher then usual. Something might be up...not sure.Dmitry Vinnik
ShowReel:
It started off rendering fast, but overtime, something happened. There isn't any one thing that I can think of, but something is broken.Bobby Parker
phone: 2188206812
- Windows 11 Pro
All night an about 1/2 the way done. I'll have to shelf this for now, the Corona one worked for the client. The project will change, so I'll visit again, then.Bobby Parker
phone: 2188206812
- Windows 11 Pro
