David White Lane
  • #91
    I never pick subpixel mapping and I am using BF. I tried with IRR, however, it took just as long. I used the new defaults (BF+LC)
    Originally posted by Morbid Angel View Post
    Well if you don't use subpixel mapping and also use brute force for primary you will get this kind of render time. What were your settings?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #92
      I mean, I tried almost every combination and landed on the defaults, because nothing else was any faster. Everything, except subpixel mapping enabled.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
      • #93
        What kind of monster graphic card/s do you have? I have the GeForce GTX 970 and I got a memory error within minutes. For some reason the bump map got exaggerated on yours. Thanks for looking into this.
        I have to confess that I'm using 5x GTX Titan X who are overclocked so it's about the same power as 7 cards. It's actually really fun to work with those
        At least you never worry about settings anymore.
        Stan
        3LP Team
        • #94
          WOW! What would that setup cost?
          Stan
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #95
            Quite a bit TBH.
            We actually bought 7 cards to get in the node but have only be able to get 5 ATM, we will give it a second go after New Years
            Stan
            3LP Team
            • #96
              Tell us how it goes... insane.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
              • #97
                Here are two more views. This is in the great room and I used Progressive, with basically the defaults. I let it run for three hours and saved from the VFB. The second run ran longer, however oddly enough, it's still noisy. I can deal with 4k in 3 hours.
ID:	859407 Click image for larger version
Name:	great room 2.jpg
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #98
                  looks good but I think the walls feel a bit dry as any painted interior wall should have some level of gloss. Also about your render times, I see in the second image you are using dof in render? This would surely raise the render time
                  Dmitry Vinnik
                  Silhouette Images Inc.
                  ShowReel:
                  • #99
                    Yes. the second one I did use DOF, which did add time, but not a whole lot.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • Updated front
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                      • Looks nice, reminds me of old school watercolor renderings.
                        I guess it's the color palette
                        • Update - He loved the first low resolution and he is wondering why they are not the same. I pointed out that a lot of the magic happens in Photoshop. This one is as close to the original I could get.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                          • Looking good Bobby. It might be that your max reflections are snubbing your rendertimes? I rarely go above 3 in any of my materials, unless it's a mirror or something. Also, where did you get the curtains? The models look nice.
                            • Originally posted by glorybound View Post
                              [ATTACH=CONFIG]27890[/ATTACH]
                              You don't work non destructive?
                              A.
                              www.digitaltwins.be
                              • Nice one!
                                I like the softer versions over the more contrasted ones.
                                Alain Blanchette
                                www.pixistudio.com
