The glass material has an alpha image for "uv filter - 001", the previous post contains the alpha channel for the metal material and it's under the glass. In fact you can see the diffraction at the edge of the glass that is over the sign.
The glass material has his alpha image and the metal material also, so the diffuse map you can see in the metal slot IS the alpha channel I posted before.
