So Natty, how many total GHZ are you running your renderings on? And please do show your final image cause I'm still working on mine!....3 hours my a**!
1 of 10 .... : )
well 6 x this .... = 36 gig.. in total ....... a little over 6 gig per machine
Geez man! I'm am right in the middle of putting together one of those systems! Thats awesome. Are you using the stock fans & heatsinks or something different? I decided to go with these silent coolers, thanks to a tip from somebody on cgarchitect. I heard the xeons make a LOT of noise when on full load.
product: http://www.orbitmicro.com/products/a...W-NPTXC-01.htm
review: http://www.ctechnet.com/hardware/Coo...w-nptxc-01.htm
Those particular ones fit the Asus PC-DL board, but I'm sure there are others similar.
Ok this was the update version Sent to the client ... @ 8.30 this morning ... so i had the weekend to render out @ highres...
Hi Mark ..
The back wall is backed glass and the image outside was quickly thrown on this morning ...so not so hot ..i agree ..
as always good job
I like it very much especially the white walls with the correct bleeding apport and the shadow density
I would like to see the floor with more than 1 for the blur in bitmap parameters to get a kind of fillet on the bumped grid
could u explain the settings?
congratulations
byeWorkstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
https://www.facebook.com/essetreddi..../photos_albums
yeah the floor could do with a little chamfer ... but in reality the edges of the stone tiles are pretty sharp...
here's some screen grabs of the setting's.
Good job man. I'm still working on mine, which also uses a back painted glass wall.
Do you find that checking 'smooth surface shadows' makes a difference? I thought in the current manual they said that that option doesn't work so well yet.
sorry i forgot to put the third vray light's setting's aswell.. the lights with the store with Irr map ticked is just to get light into the scene.. the other's are used to pick up detail.
thank u
NAtty
very interesting!
