Here's an update... ::
Some Early WIP Delta Design's
thanks guy's ..
@ Tom .. i know what you mean about the grain ... ive been having a battle with vray on this new build ... i just cant shift the grain the subdiv's of this Ali is 30 ?? but still grain, also with high QMC settings.. im miffed ?
@ s0real .. i got the Job yesterday morning and its to be complete by lunchtime today.. so a quick turn around.
Hi Natty about the grain.
this is some thing we should ask to vlado .
the stronger grain is something also some of my partners dont like.
it seems very difficult to make it as smooth as with the older 1.470.
maybe theres an easy way, vlado can tell us, or maybe explain, why the grain apears so much stronger.
Tom
Yeah i agree .... i just cant smooth it out ? really been Bugging me .. there's no way im going to use Interpolation blur it ... i'll just lose the detail.
nice render. How did you make that cable?
First i created a spline and turned on Display Render Mesh.
Set the sides and steps to get a dense mesh..
Then converted to a Editable Poly, selected all the edges, Chamfered then extruded ... then Subdivided the surface by 2 Iterations... and Bingo i think it worked well..
Hi natty!
Just a little something that I find as a mistake - the two holders that hold the lamp on the sides are not on the diameter of the lamp. If one wants to rotate it, so it looks on the other side, it would be impossible.
About the graininess - can you tell me something more about the material you are using? Also you have Irr+QMC in the GI, don't you?
... and the hose is really nice ... why did you chamfer ALL the edges (or at least that is what I understood) - from the image I can see only the cross-section edges chamfered, not the length ones. And why did you chamfer them before extrusion of the faces. I usually do it the other way around - extrude to have the shape, then apply subd to see the preliminary result and chamfer the edges necessary (takes a hell of a time ) Editable Poly rulez though, I like it much better than Editable Mesh.Best Regards,
Tisho
Hey Tisho ...
the unit rotate's from the fixing @ the top and also the centeral rotation from the pivot.... so really its not designed to point straight down ...
and the reason for the chamfer was to subdivide ...
Here's the settings..
a Long one...
