It will be interesting to see how the scene renders in 3dsmax 2012 (to be released April 8th). I converted the test scene for use with iray, and had many problems with 3dsmax 2011 crashing because of the scene size (which should not be the case, there is nothing in the scene that should be a problem).
Maybe 2012 will help with rendering also. It's supposed to drastically improve viewport speed and geometry import, which I've had nothing but problems with in 2010 and 2011.
Any chance of posting the iray scene? I would like to see how they compare.
RT 2.10.01 with the new beta drivers seems a little slower but nearly identical than RT2.0 with 2.70 driver when rendering little path per pixel.
When you let cooking longer, the new driver + RT 2.10.01 look a little more fast .
GHiOM = Guillaume Gaillard
freelance 3D artist www.ghiom.com
Some very preliminary results with the latest CPU drivers for OpenCL from Intel and AMD. Note: on the 24-core machines, neither driver seems to utilize all CPU cores fully - I'm not yet sure why, but we will be looking into it. If all the cores were working to the max, then the results should be even better.
P.S. At a middle of render time system is out of (64 GB!!!) memory and start swapping...
P.P.S. Trying to run DR on same machine (on second CPU group). It has 4 CPUs (80 cores in 2 CPU groups)...
Thanks... Do U use special version of V-Ray to run Intel/AMD OpenCL?
Yes, I had to make some minor changes to the OpenCL code to get it to compile on Intel OpenCL and also some changes to allow one to specify CPU OpenCL plaftorms for rendering. If you are interested in this build, please email me to vlado@chaosgroup.com. However, like I said, we need to make some other changes to utilize all CPU cores through OpenCL.
