Computer Quote
Computer Quote
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
I have the GTX 960, so I don't need a card.Bobby Parker
phone: 2188206812
- Windows 11 Pro
AFAIK, the 4930 is a LGA-2011 socket not a LGA-2011v3 so it basically won't fit and is incompatible. Your local computer shop should know this! You'll either need to switch to a different CPU (5820k is equivalent) or switch out the MB and RAM to a x79 board and ddr3 ram. Both options will save you money as the MB and RAM should be cheaper if you stay with the 4930 or the CPU is cheaper if you switch to the 5820.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
Good to know. They are building it for $150, but I am buying the parts.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I would difinitelly go for i7 5960x.
I got 4 machines with 3930K (very simillar to 4930K) and they are working OK ... but if you choose x5960 the total cost increases 25% but the rendering performance increases 40%.i-9 7980XE at stock, G. Skill RipjawsV 64GB RED, MSI GeForce GTX 1080 Ti GAMING X 11GB, http://fractalmind.eu
The computer shop guy said that, that configuration will only give me a slight increase in performance from what I currently have. He recommends the:
'The only reservation I have about this build is you will only get a slight boost in performance. A step up in significant performance would be a newer Xeon processor but I am told it would get into the 4-6 thousand range."Bobby Parker
phone: 2188206812
- Windows 11 Pro
Do not believe him. I don't think this guy knows enough about rendering with V-ray.
Below are 2 results from this thread:
http://forums.chaosgroup.com/showthr...INTERIOR-SCENE
95s. (5960x) vs. 155s. (4930K)
Originally posted by JezUK View PostNew build over the weekend.
i7-5960x OC
32Gb Ram
M2 SSD
Quadro K4200
3DS Max 2016
V-Ray 3.20.
Embree ON
1m 35.4sec
Originally posted by S_K_I View PostI just discovered this thread, I love it so I decided to test my rig:
Asus Sabertooth x79
4930k (6-core) @ 4.2ghz
32 GB Ram
V-Ray 3.10.03
3ds Max 2015
2.50s No Embree
2.35s Embree Oni-9 7980XE at stock, G. Skill RipjawsV 64GB RED, MSI GeForce GTX 1080 Ti GAMING X 11GB, http://fractalmind.eu
So, the 4960 is the way to go?Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostSo, the 4960 is the way to go?
And if you compare 4960x OC @ 4,2GHxZ vs 5960x OC @ 4,2GHz it still much better to take 5960x.
In my opinion 5960x is at the moment best $/performance choice.i-9 7980XE at stock, G. Skill RipjawsV 64GB RED, MSI GeForce GTX 1080 Ti GAMING X 11GB, http://fractalmind.eu
gotcha, thanks!Originally posted by baastyan View PostI don't think so. You have only 6 cores in 4960. And 5960x has 8 cores.
In my opinion 5960x is at the moment best $/performance choice.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby Parker
phone: 2188206812
- Windows 11 Pro
What are you using for your OS HDD? I highly recommend an M.2 drive as the OS drive. Motherboard supports them at PCIe x4 speed, so it's the fastest HDD interface on the market right now. Just a thought.
Yes. I was going to add an SSD for the OS.Originally posted by Donald2B View PostWhat are you using for your OS HDD? I highly recommend an M.2 drive as the OS drive. Motherboard supports them at PCIe x4 speed, so it's the fastest HDD interface on the market right now. Just a thought.Bobby Parker
phone: 2188206812
- Windows 11 Pro
