Computer Quote
  • Computer Quote
    I just got a quote from my local computer shop. How does it look? Other than the SATA drive, which I'll change to an SSD, does it look good. The price is right. I will have the one workstation, so I am not sure if I should get the i7 or the dual Xeon.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I have the GTX 960, so I don't need a card.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      AFAIK, the 4930 is a LGA-2011 socket not a LGA-2011v3 so it basically won't fit and is incompatible. Your local computer shop should know this! You'll either need to switch to a different CPU (5820k is equivalent) or switch out the MB and RAM to a x79 board and ddr3 ram. Both options will save you money as the MB and RAM should be cheaper if you stay with the 4930 or the CPU is cheaper if you switch to the 5820.
        Good to know. They are building it for $150, but I am buying the parts.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I would difinitelly go for i7 5960x.
          I got 4 machines with 3930K (very simillar to 4930K) and they are working OK ... but if you choose x5960 the total cost increases 25% but the rendering performance increases 40%.
          i-9 7980XE at stock, G. Skill RipjawsV 64GB RED, MSI GeForce GTX 1080 Ti GAMING X 11GB, http://fractalmind.eu
            The computer shop guy said that, that configuration will only give me a slight increase in performance from what I currently have. He recommends the:
            'The only reservation I have about this build is you will only get a slight boost in performance. A step up in significant performance would be a newer Xeon processor but I am told it would get into the 4-6 thousand range."
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Do not believe him. I don't think this guy knows enough about rendering with V-ray.
              Below are 2 results from this thread:
              http://forums.chaosgroup.com/showthr...INTERIOR-SCENE
              95s. (5960x) vs. 155s. (4930K)
              Originally posted by JezUK View Post
              New build over the weekend.
              i7-5960x OC
              32Gb Ram
              M2 SSD
              Quadro K4200
              3DS Max 2016
              V-Ray 3.20.
              Embree ON
              1m 35.4sec
              Originally posted by S_K_I View Post
              I just discovered this thread, I love it so I decided to test my rig:
              Asus Sabertooth x79
              4930k (6-core) @ 4.2ghz
              32 GB Ram
              V-Ray 3.10.03
              3ds Max 2015
              2.50s No Embree
              2.35s Embree On
                So, the 4960 is the way to go?
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  I don't think so. You have only 6 cores in 4960. And 5960x has 8 cores.
                  And if you compare 4960x OC @ 4,2GHxZ vs 5960x OC @ 4,2GHz it still much better to take 5960x.
                  In my opinion 5960x is at the moment best $/performance choice.
                    gotcha, thanks!
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      I am pretty sure you won't regret it.
                      gotcha, thanks!
                        How's this looking?
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          What are you using for your OS HDD? I highly recommend an M.2 drive as the OS drive. Motherboard supports them at PCIe x4 speed, so it's the fastest HDD interface on the market right now. Just a thought.
                          Troy Buckley | Technical Art Director
                          Midwest Studios
                            Yes. I was going to add an SSD for the OS.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                              make sure you get a pcie m.2 drive not a sata m.2 drive. you can tell because they are the more costy ones. a sata m.2 drive has no advantage over a normal sata ssd.
