Hello,
I am still having problems with getting a nice result when using noise in bump slot.
Thing is that I have a lot of plastic shaders with varying types of grain. So far it all works fine in CPU, but in GPU mode the noise texture seems to be bakes or something like that. It looks low res and misses all the subtle details. I told Vray to use the full size texture in full float, still the same.
So, how can I finally get this to work?
First set of images has larger grain, second set smaller grain. Left is CPU, right GPU.
