Noise in bump: Still struggling to get any decent looking output
  • Noise in bump: Still struggling to get any decent looking output
    I am still having problems with getting a nice result when using noise in bump slot.
    Thing is that I have a lot of plastic shaders with varying types of grain. So far it all works fine in CPU, but in GPU mode the noise texture seems to be bakes or something like that. It looks low res and misses all the subtle details. I told Vray to use the full size texture in full float, still the same.
    So, how can I finally get this to work?
    First set of images has larger grain, second set smaller grain. Left is CPU, right GPU.
ID:	886159Click image for larger version
ID:	886161Click image for larger version
    This is Max right ?
    Which V-Ray version ?
    Can you share a screenshot of the shader network for the material with the bump or the scene ?
    Best,
    Blago.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      This is Max 2016, 3.5 Beta 1. Scene attached. Thanks Blago!
      https://transfer.px2.de/_ckVRN18ZUdg5sR
        Thanks, I will look into that asap.
        Best,
        Blago.
        V-Ray fan.
        RTX ON
          Any news regarding this problem?
            Yep, I'm having the same issue with noise maps for bump in RT GPU too. This forces me to use Vray Adv instead of RT which is 2-3 times slower compared to GPU for the particular scene I'm rendering. Here are some examples from that scene:
ID:	866153 Click image for larger version
            With RT, I had to use VrayColor2Bump with the Noise map as per the recommendation in the Footnotes of this help page otherwise it wouldn't appear.
            Am I adding procedural bump maps with RT CUDA wrong or is this a problem with the bump in RT?
            Aleksandar Mitov
            www.renarvisuals.com
            office@renarvisuals.com
            AMD Ryzen 9 9950X 16-core
            96GB DDR5
              I am looking into that as we speak, but I couldn't fix that particular case with that geometry for 3.5 Beta 2.
              @Alex_M - The renders that you have shown, are they made with nightly or Beta 1 (Beta 1 had bugs with that) ?
              V-Ray fan.
              RTX ON
                This was rendered with the official Beta 1 release. I don't have access to the nightlies. It would be nice, though. I mean, I can access the download panel but the latest version I see is vray_adv_35002_<maxversion>_27140.rar in folder 11.01.2017. Is this the latest nightly?
                Aleksandar Mitov
                96GB DDR5
                  @Alex_M The final Beta 2 will be out soon anyway. If the problem persists it will be best to send a scene as well. Sorry for the troubles.
                  @kosso_olli Still looking into your scene, will update when I have something.
                  Best,
                  Blago.
                  V-Ray fan.
                  RTX ON
                    Alright, can't wait to try it out! I'll test the same scene with it when it's out and let you know if it's better.
                    Aleksandar Mitov
                    96GB DDR5
                      @kosso_olli - your issue should be fixed for 3.50.03.
                      Peter Matanov
                      Chaos
                        Best,
                        Blago.
                        I just tested with beta 2 and the bump issue for me has been fixed. It looks pretty much identical to Vray Adv. now. Thanks!!!
                        Aleksandar Mitov
                        96GB DDR5
                          Nice! Will try it when it is available.
